Suunto EON Steel
The fully customizable dive computer with a bright color screen, extremely durable construction and mobile connectivity. Made in Finland.
Extreme durability with full customization
The robust Suunto EON Steel is designed for divers who demand the most of their dive computer. With the extremely durable construction, wide-angle BrightSee™ color screen and multiple gas support, this dive computer is ideal for advanced diving. Customizable features and views add a new dimension to your diving when exploring the blue unknown. Tested in the toughest diving conditions, Suunto EON Steel is your reliable partner in all conditions.
Bühlmann 16 with Gradient Factors is now available!
Suunto EON Steel can now be upgraded to include an additional algorithm for added diving possibilities.
HIGHLIGHTS
- Fully customizable
 - Superior viewing
 - Robust construction
 - Wireless connectivity
SPECIFICATIONS
                  Measurements104.6 x 60.5 x 23.1 mm / 4.12 x 2.38 x 0.91 "
                  Weight347 g / 12.24 oz
                  Bezel material:Stainless steel
                  Glass material:Xensation Glass
                  Case material:Composite
                  Strap material:Elastomer
                  What's in the box?Suunto EON Steel, USB Cable, Quick Guide, Legal leaflet, Protective boot, Display scratch guard sticker, Bungee adapter and cord
                  Country of manufactureFI
TECHNICAL SPECIFICATIONS
                      Bezel materialStainless steel
                      Glass materialXensation Glass
                      Case materialComposite
                      Strap materialElastomer
                      Flip display✔
                      Water resistance150 m (ISO 6425, EN 13319)
                      Battery typerechargeable lithium-ion
                      Firmware upgradable✔
                      Time, date✔
                      Stopwatch timer✔
                      LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
                      BacklightLED
                      Configurable backlight✔
                      Display typecolor TFT
                      Display resolution320 x 240
                      Metric and imperial units✔
                      Battery indicatoricon + dive hours remaining
PHYSICAL SPECIFICATIONS
                      Operating temperature0° C to +40° C / +32° F to +104° F
                      Storage temperature-20 ° C to +50 ° C / -4° F to +122° F
                      Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
                      In time mode2 months
COMPASS
                      Digital compass✔
                      Tilt compensationup to 45°
                      Declination correction✔
                      Direction scaledegrees
                      Needlecompass rose
                      Bearing lock with direction indicator✔
                      Globally balanced✔
                      Compass accuracy+/- 15°
                      Compass resolution1°
CONNECTIVITY
                      Connectivity (between devices)inductive (Tank POD), Bluetooth Smart
                      Compatible with Suunto app✔
                      Compatible with DM5✔
                      Log transferBluetooth Smart / USB cable
                      Smartphone compatibilityMost common models supported
OUTDOOR FUNCTIONS
WEATHER
                      Temperature✔
                      Temperature display range-20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F)
                      Temperature resolution1° C / 1.5° F
DIVING FUNCTIONS
BASIC
                Altitude adjustment0 - 300 m / 300 -1500 m / 1500 - 3000 m
                Ascent time display0 - 999 min ( > after 999)
                CNS/OTU (OLF) calculation✔
                Custom displays4 per dive mode
                Decompression modelSuunto Fused™ RGBM
                Deep Stop✔
                Dive historylifetime
                Dive time0 to 999 min
                Gas consumption (real-time)✔
                Gas max pO2manual 0.5 - 1.6 / fixed 1.6
                Gas switching✔
                Gas time✔
                Gasesup to 10 gases (Oxygen 5 - 99% / Helium 0 -95%)
                Gauge✔
                Logbook bookmarks✔
                Logbook memory200 h
                Logbook sampling rates10 s
                Maximum operating depth (EN 13319)80m
                Nitrox (and air)✔
                No fly time✔
                No-decompression planner✔
                Personal adjustmentP+2, P+1, P0, P-1, P-2
                Rebreather (CCR), fixed point✔
                Safety Stop✔
                Surface time0 to 100 h
                Timer✔
                Trimix (mixed gas)✔
                Visual styleClassic/Graphical/Prominent
                Wireless air integrationoptional (up to 20 different tanks with Suunto Tank POD)
DIVE ALARMS AND NOTIFICATIONS
                CNS/OTU (OLF) 80% / 100%✔
                Decompression ceiling violation✔
                Deepstop violation✔
                Diluent high pO2✔
                Diluent low pO2✔
                Diluent switched automatically✔
                Dive time✔
                Gas time✔
                High pO2 (hyperoxic)✔
                ICD warning✔
                Low pO2 (hypoxic)✔
                Maximum depth✔
                Switch gas (better gas is available)✔
                Tank pressure✔
                Too fast ascent✔
REBREATHER
                Diluentsup to 10 diluents (Oxygen 5 - 99% / Helium 0 - 95%)
                Bailout✔
                High/low setpoints✔
                Custom setpoint✔
                Manual/automatic setpoint switching✔
