Suunto Core Alpha
Stealth
Rugged Outdoor Watch Designed for Off-Grid Adventures
- Mineral crystal display with durable aluminum bezel
 - Night vision Goggle compatible red backlight for stealth use
 - ABC sensors: altimeter, barometer, compass, plus weather tracking
 - Water resistant up to 30 meters; suitable for shallow snorkeling (10 m)
 - Time, date, and multiple watch functions for everyday utility
 - Up to 12 months of battery life in time mode
Choose your Color
SUUNTO CORE ALPHA
Suunto Core Alpha packs the key outdoor features in robust construction with a comfortable yet durable textile strap. Combining an altimeter, barometer and compass with weather information, it will bring out the explorer in you. The night vision goggle friendly red backlight helps you stay unnoticed when hunting.
Suunto Core Alpha is designed and made in Finland with the quality that Suunto is known for. Tested to military standards (MIL-STD-810), the watch will make sure your journey is safe and successful even in the toughest and most demanding conditions. Suunto Core Alpha has passed 9 tests, including pressure, heat/cold, shock, drop, freeze/thaw, rain, humidity and dust.
Key features
Barometer
Compass
Altimeter
Red backlight
Weather functions
Sunrise and sunset times
30 m water resistant
Benefits
- Altimeter
 - Barometer
 - Compass, adjustable declination
 - Temperature
 - Storm alarm
 - Sunset/sunrise times
 - Tested to military standards
 - Made in Finland
 - Red backlight, night vision goggle friendly
 - Textile strap (Berry amendment compliant)
 - User replaceable battery (CR2032), battery life ~12 months
 - Multiple watch, date and time functions
 - 30 m / 100 ft water resistance
 - Depth meter for snorkeling (10 meters)
 - Metric and imperial units
 - Multilingual menu: EN, DE, ES, FR
      SPECIFICATIONS
                  Measurements49.5 x 49.5 x 15.1 mm / 1.95 x 1.95 x 0.59 "
                  Weight67 g / 2.36 oz
                  Bezel material:Aluminum
                  Glass material:Mineral crystal
                  Case material:Composite
                  Strap material:Textile
                  What's in the box?Suunto Core Alpha Stealth and Quick Guide
                  Country of manufactureFI
TECHNICAL SPECIFICATIONS
                      Bezel materialAluminum
                      Glass materialMineral crystal
                      Case materialComposite
                      Strap materialTextile
                      Wrist sizes140-240 mm
                      Water resistance30 m
                      Battery typeCR2032
                      User replaceable battery✔
                      Time, date✔
                      Alarm clock1 daily alarm
                      Dual time✔
                      Countdown timer✔
                      Stopwatch timer✔
                      LanguageEN, DE, ES, FR
                      BacklightLED
                      Configurable backlightactivation: 1 button, all buttons
                      Button lock✔
                      Display typematrix
                      Metric and imperial units✔
                      Battery indicatorlow battery indicator
PHYSICAL SPECIFICATIONS
                      Operating temperature-20° C to +60° C / -5° F to +140° F
                      Storage temperature-30° C to +60° C / -22° F to +140° F
BATTERY LIFE
                      In time mode12 months
COMPASS
                      Digital compass✔
                      Direction scaledegrees
                      Needlenorth indicator
                      Bearing lock with orienting indicator✔
                      Compass accuracy5°
                      Compass resolution1°
OUTDOOR FUNCTIONS
ALTIMETER
                      Barometric altitude✔
                      Altitude graph✔
                      Altitude difference✔
                      Total ascent/descentair pressure based
                      Automatic alti/baro profile✔
                      Log recording rate1, 5, 10, 30, 60 s
                      Resolution1 m
                      Range-500 - 9000 m
WEATHER
                      Sunrise/sunset times✔
                      Storm alarm✔
                      Sea level pressure✔
                      Temperature✔
                      Temperature display range✔
                      Temperature resolution1°
                      Pressure resolution1 hPa / 0.03 inHg
                      Max weather recording length7 days
                      Sea level pressure graph✔
                      Weather trend indicator✔
SPORT EXPERTISE
HUNTING
                      Red backlight, compatible with night vision goggles✔
DIVING FUNCTIONS
FREEDIVING
                Depth meter for snorkeling10 m
