How to Calculate Maximum Heart Rate
SuuntoRunJuly 21 2025
Maximum heart rate (HRmax) is the highest number of beats per minute your heart reaches during hard exercise. It helps define your training zones and intensity levels.
Knowing your HRmax helps control workouts, prevent overtraining, and track improvements. It also supports heart health and fitness planning.
HRmax is a key number in any serious training plan.
Content Table:
Understanding Basic Heart Rate Concepts
Resting heart rate is your heart rate when you're calm and inactive. Most adults have a resting heart rate between 60 and 100 beats per minute.
Maximum heart rate (HRmax) is the highest your heart rate goes during intense activity. It helps set safe and effective training limits.
Target heart rate zones are ranges based on your HRmax. These zones guide how hard you should train, depending on your fitness goals. Lower zones help with endurance and recovery. Higher zones help build speed and strength.
Several factors affect heart rate. These include age, fitness level, health conditions, and medications. For example, beta-blockers can lower both resting and maximum heart rate. Altitude and temperature can also raise your heart rate during activity.
Tracking heart rate helps you adjust effort, stay safe, and improve over time.
how to calculate maximum heart rate
Methods for Calculating Maximum Heart Rate
Here are some common methods for calculating maximum heart rate:
1. Traditional Formula: 220 − Age
  • The classic formula (220 minus your age) is simple and widely used.
  • However, it has significant accuracy issues: studies report errors of ±10–12 beats per minute and population-wide biases.
  • Originally based on limited data (≈11 small studies, many middle-aged or with heart disease), its value lies in offering an instant estimate when more precise methods aren’t feasible.
2. Alternative Formulas
For improved accuracy, especially across different age groups and fitness levels, consider these research-backed equations:
  • HUNT (Nes et al., 2013): HRmax = 211 − (0.64 × age) — Standard error ≈ 11 bpm.
  • Tanaka (Tanaka et al., 2001): HRmax = 208 − (0.7 × age) — Derived from meta-analysis (~18,700 subjects), accuracy ~±10 bpm.
  • Gulati (2010, women only): 206 − (0.88 × age) — Adjusts for sex-specific differences.
Performance note: Fox and Tanaka formulas tend to overestimate in women (~5 bpm) and underestimate in men (~3 bpm) in some athletic groups. Nonlinear or machine-learning models slightly outperform linear formulas but still carry ±11 bpm errors.
3. Lab Testing (Exercise Stress Test)
  • The most accurate way to determine HRmax: a supervised maximal test with ECG monitoring (e.g., treadmill, cycling).
  • Often used in clinical settings and athlete assessment, this method measures real-time cardiac response to full exertion.
  • Despite being precise (±2 bpm accuracy), it requires specialized equipment and medical oversight.
How to Use Your Maximum Heart Rate
1. Set Precise Target Zones
Health organizations recommend training within specific zones of HRmax: 50–70 % for moderate effort and 70–85 % for vigorous effort. These ranges enhance cardiovascular health and endurance.
For example, a 40‑year‑old with HRmax ≈ 180 bpm should aim for 90–126 bpm in moderate sessions and 126–153 bpm in vigorous workouts.
According to heart.org, here is the general guide by age:
Age
Target Heart Rate Zone 50%–85%
Average Maximum HRmax
20
100–170 bpm
200 bpm
30
95–162 bpm
190 bpm
35
93–157 bpm
185 bpm
40
90–153 bpm
180 bpm
45
88–149 bpm
175 bpm
50
85–145 bpm
170 bpm
55
83–140 bpm
165 bpm
60
80–136 bpm
160 bpm
65
78–132 bpm
155 bpm
70
75–128 bpm
150 bpm
75
73–123 bpm
145 bpm
80
70–119 bpm
140 bpm
85
68–113 bpm
135 bpm
90
65–111 bpm
130 bpm
2. Improve Accuracy with Heart Rate Reserve (HRR)
The HRR method (Karvonen formula) refines target zones by including resting heart rate (RHR):
  • HRR = HRmax – RHR
  • Target HR = (HRR × % intensity) + RHR
For example, HRmax = 180 bpm and RHR = 60 bpm yields HRR = 120 bpm. At 70 % effort: (120 × 0.7) + 60 = 144 bpm. This method aligns better with individual fitness than %HRmax alone.
3. Why HRR Matters
HRR correlates with cardiovascular fitness—higher HRR often reflects greater fitness. Studies link low HRR to increased health risks, underscoring HRR’s value in training as well as for rehab and clinical patients.
4. Alternative Checks
If you can't wear a device, use subjective tests like the “talk test” or Borg scale. Still, HRR gives a quantifiable edge.
what is maximum heart rate
Monitoring and Tracking Your Heart Rate
You can track heart rate manually or with a device.
Manual check:
Use your fingers to find your pulse on the wrist or neck. Count the beats for 15 seconds. Multiply by 4 to get beats per minute. This works at rest, but it's not reliable during exercise.
Wearable tracking:
Devices like watches and chest straps give continuous heart rate data. These are better for workouts and daily trends.
The Suunto Race S uses wrist-based sensors to track your heart rate in real time—even in cold weather or during intense movement. It also stores long-term data, so you can see trends, effort levels, and recovery patterns.
The Race S uses optical sensors to measure heart rate at the wrist without a chest strap. It works reliably even in cold or high-motion conditions like trail runs or interval workouts. For the most accurate results, especially during intense training or in extreme weather, athletes can pair it with the Suunto Smart Sensor chest strap.
The device logs 24-minute average heart rate trends and shows a 12-hour history through its HR widget. This lets you track recovery, monitor stress, or spot elevated exertion over time.
When to check:
  • During warm-up
  • At peak effort
  • During cooldown
  • At rest (morning RHR)
Tracking helps you stay in the right zone and avoid overtraining.
Factors Affecting Maximum Heart Rate
Several factors influence your HRmax:
Age
Age is the strongest predictor of HRmax, accounting for approximately 70–80% of its variance. HRmax generally declines with age, and this decline accelerates in older populations.
Sex
While men and women see similar age-related drops in HRmax, women may maintain slightly higher HRmax levels into midlife.
Fitness Level & Training Status
Regular endurance training can shift your heart-rate response: some athletes reach higher peak heart rates, while others maintain output with lower rates, underlining that HRmax is influenced not just by age but also by fitness status.
Genetics
Genetics play a key role in cardiovascular capacity. Genetic variation may account for 25–65% of differences in cardiorespiratory fitness, including HRmax.
Health & Medications
Conditions like heart disease and medications such as beta-blockers reduce both resting and maximum heart rate, so always consult a healthcare professional when interpreting HRmax data.
Environment: Heat & Altitude
Heat and humidity trigger cardiovascular drift — heart rate increases over time despite stable effort, due to dehydration and increased blood flow to the skin. High-altitude exercise raises heart rate by 10–30% to maintain oxygen delivery.
Tracking changes over time helps you understand how these factors affect your training.
Common Questions and Safety Tips
Q: Are HRmax formulas accurate for everyone?
A: No. Most formulas give estimates. They may not work well for older adults, highly trained athletes, or those with health issues. Lab testing or wearable tracking provides better insight.
Q: What if you take heart medication?
A: Beta-blockers and similar drugs lower your heart rate. Formulas may give results that are too high. Ask your doctor before using HRmax for training.
Q: When should you stop exercising?
A: Stop right away if you feel:
  • Chest pain
  • Dizziness
  • Severe shortness of breath
  • Faintness
These are signs you may be overdoing it. Always listen to your body.
Conclusion
Understanding your maximum heart rate helps you train with purpose and track progress over time. It guides how hard to push and when to recover. Whether you’re hiking, running, or cross-training, using a device like the Suunto Race S makes heart rate monitoring simple and precise.
Empfohlene Produkte von Suunto
