Suunto Vertical 2
Arctic Gray
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Choose Your Color
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
SPEZIFIKATIONEN
Maße48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
Gewicht87g
Lünettenmaterial:Stainless steel
Glasmaterial:Sapphire crystal
Gehäusematerial:Glass fibre reinforced polyamide
Armbandmaterial:Silicone
HerstellungslandCN
Technische Daten
ALLGEMEIN
LünettenmaterialStainless steel
GlasmaterialSapphire crystal
GehäusematerialGlass fibre reinforced polyamide
ArmbandmaterialSilicone
Gewicht87g
Handgelenkgrößen125-175 mm
Armbandbreite22 mm
Integrierte Herzfrequenzmessung am Handgelenk✔
Anpassbare Zifferblätter✔
Touchscreen-Sperre✔
Touch-Display✔
Farbdisplay✔
Vibrationsalarm✔
Wasserbeständigkeit100 m
Batterietyprechargeable lithium-ion
Firmware aktualisierbar✔
Zeit, Datum✔
Wecker✔
Doppelzeit✔
Automatische Zeitmessung✔
Countdown-Timer✔
Stoppuhr-Timer✔
SpracheCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
HintergrundbeleuchtungLTPO AMOLED
Konfigurierbare Hintergrundbeleuchtungautomatic brightness
Tastensperreduring exercise
Displaygröße1,5"
Displaytypmatrix
Displayauflösung466 x 466
Metrische und imperiale Einheiten✔
Automatische Sommerzeit✔
Batterieanzeigepercentage / icon
Blutsauerstoff✔
Always-on-Display✔
ÄUSSERE MERKMALE
Betriebstemperatur-20° C to +55° C / -5° F to +130° F
Aufbewahrungstemperatur-20° C to +55° C / -5° F to +130° F
Empfohlene Batterieladetemperatur0° C to +45° C / +32° F to +110° F
BATTERIELEBENSDAUER
Intelligente Ladeerinnerungen✔
Tägliche Nutzung: Smartwatch-Modusup to 20 days
Tägliche Nutzung: Nur Standby-Modusup to 40 days
Training: All-Systems GNSS-Modus + Multi-Bandup to 65h (AOD 60h)
Training: All-Systems GNSS-Modus + Single-Bandup to 75h (AOD 70h)
Training: Batterieversprechen aller Modi65h / 75h / 110h / 250h
Training: Energiesparende GNSS-Modiup to 250h
KOMPASS
Digitaler Kompass✔
Neigungskompensation✔
Neigungskorrektur✔
Richtungsskaladegrees / mils
Nadelnorth indicator
Genauigkeit5°
Skaleneinteilung1°
KONNEKTIVITÄT
Konnektivität (zwischen Geräten)Bluetooth
Kompatibel mit der Suunto App✔
Telefonbenachrichtigungen auf der Uhr✔
Mediensteuerungen auf der Uhr✔
Verschicke vordefinierte Antworten auf eingegangene Nachrichten von der UhrAndroid only
Mit Online-Sport-Communities kompatibelStrava, TrainingPeaks and more
Uhrensoftware-Updates über die Cloud✔
Automatische Over-the-Air-Software-Updates✔
Smartphone-KompatibilitätMost common models supported, check here for detailed compatibility list
24/7
AKTIVITÄTSVERFOLGUNG
Schrittzähler✔
Kalorienverbrauch✔
Aktivitätszielesteps, calories
Aktivitätsverlauf✔
Kalorienverbrauch und Herzfrequenz während Ihrer täglichen Aktivitäten✔
Tägliche Aufzeichnung der niedrigsten Herzfrequenz✔
SCHLAFAUFZEICHNG
Schlafdauer✔
Schlafenszeiten✔
Zeit im Wachzustand✔
Tiefschlaf✔
Durchschnittliche und niedrigste Herzfrequenz im Schlaf✔
Leichter Schlaf✔
REM✔
HRV im Schlaf✔
Schlafqualität✔
BELASTUNG UND ERHOLUNG
Tägliches Ressourcenniveau✔
Belastungs- und Erholungsstatus✔
HRV-Messung✔
OUTDOOR-FUNKTIONEN
GPS TRACKING UND NAVIGATION
Offline-Karten auf der Uhr✔
SatellitensystemeGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Simultane Nutzung von Satellitensystemen4
Max. verbundene Satelliten32
Intelligente BatteriemodiPerformance, Endurance, Ultra, Tour, Custom
GPS-AufzeichnungsrateBest, Good, OK, Low
Wegpunkt- und visuelle Routen-Navigation✔
Vergrößerungsstufen in der Navigation✔
Automatische Vergrößerung anhand der Routenform✔
Echtzeit-Darstellung der Strecke✔
Routenplanung mit Höhenprofil✔
Outdoor-Gelände- und Satellitenkarten✔
Globale Heatmaps für 20 Sportarten✔
Routenplanung mit Heatmaps✔
Persönliche Routenbibliothek im Web, synchronisiert mit der Uhr✔
Snap to Route✔
Navigation mit Points of Interest (POI)✔
GPS-Routenanalyse✔
Aufzeichnen, Anzeigen und Teilen der Wegstrecke✔
Geschätzte Ankunftszeit (ETA – Estimated Time of Arrival)✔
HÖHENMESSER
Barometrische Höhenmessung✔
GPS-Höhenmessung✔
Kombinierte GPS- und barometrische Höhenmessung (FusedAlti™)✔
Höhe im Tagesmodus✔
Höhenakklimatisierung mit Blutsauerstoff✔
Gesamtaufstieg/-abstieg✔
Vertikale Geschwindigkeit✔
Automatisches Höhenmesser-/ Barometerprofil✔
Aufzeichnungsrate des Protokolls1 s
Anzeigegenauigkeit1 m
Anzeigebereich-500 - 9999 m
WETTER
Sonnenaufgangs-/Sonnenuntergangszeiten✔
Unwetterwarnung✔
Luftdruck auf Meereshöhe✔
Temperatur✔
Temperaturanzeigebereich-20° C to +55° C / -5° F to +130° F
Genauigkeit der Temperaturanzeige1° C / 1.5° F
Genauigkeit der Druckanzeige1 hPa
Höhendiagramm in der Trainingszusammenfassung✔
TRAININGSFUNKTIONEN
ALLENAMENTO A INTERVALLI
Configurazione intervalli✔
Indicazioni sugli intervalli durante l'allenamento✔
Intervalli strutturati✔
HERZFREQUENZ
Herzfrequenzgurt-KompatibilitätBluetooth HR belts
RR-Intervallwith Suunto Smart Sensor
Herzfrequenz in Schlägen pro Minute✔
Zeichnet Herzfrequenz beim Schwimmen auf✔
Herzfrequenzdiagramm in Echtzeit✔
Durchschnittliche Herzfrequenz in Echtzeit✔
Kalorien✔
Peak Training Effect✔
Persönliche Herzfrequenzzonen✔
Fitnessniveau (VO2max)✔
Erkennung des Laktatgrenzwerts✔
Erholungszeit✔
GESCHWINDIGKEIT UND STRECKE
Trittfrequenzbasierte Geschwindigkeit und Distanz✔
GPS-Geschwindigkeits- und Distanzmessung✔
Chrono✔
Foot POD-UnterstützungBluetooth Foot Pods
Autolaps✔
Manuelle Runden✔
Analyse von Tempo, Geschwindigkeitsdiagrammen und Routen auf der Karte✔
TRAININGSERHOLUNG
Befinden nach Training auf der Uhr speichern✔
Trainingsbezogene Erholungszeit✔
TRAININGSBELASTUNG
Logbuch mit Trainingsdetails✔
Trainingsbelastung mit Gesamtsummen je Sportart✔
Trainingsprotokoll für Langzeitübersichten✔
Trainingszusammenfassung mit Rundendetails✔
TEILEN UND NEU ERLEBEN
Teilen von Trainingseinheiten in den sozialen Medien✔
Bewertung und Kommentierung von Traningseinheiten✔
Folgen Sie anderen Mitgliedern und erhalten Sie Feedback über den Aktivitäten-Stream✔
KOMPETENZ IN SPORTARTEN
SCHWIMMEN
Geschwindigkeits- und Distanzdaten für Schwimmen im Becken✔
Freiwasserschwimmen Distanz✔
Schwimmzeit nach Bahnenlänge, Runde, Summe✔
Schwimmzugfrequenz, Zähler und Typ✔
Schwimmzugeffizienz (SWOLF)✔
Automatische Intervalle✔
Intervall-Rundentabelle✔
RADFAHREN
Geschwindigkeit beim Radfahren✔
Durchschnittliche Geschwindigkeit in Echtzeit✔
Bike POD mit Unterstützung von Geschwindigkeit und TrittfrequenzBluetooth Bike Pods
Unterstützung für Bike LeistungsmesserBluetooth Power meters
Bike Power (W), Durchschnitt und Maximum (mit Power-Sensor)Bluetooth Power meters
Fahrrad-Runde und maximale Rundenleistung (mit Power-Sensor)✔
Rundentabelle in Echtzeit mit Durchschnittswerten für Herzfrequenz, Leistung und Geschwindigkeit✔
Intervallführung mit Leistung/Geschwindigkeit/Herzfrequenz✔
LAUFEN
Laufgeschwindigkeit✔
Suunto FusedSpeed™✔
An Route anpassen✔
Laufleistung✔
SuuntoPlus™ Ghost runner✔
Foot POD Kalibrierungautomatic
Rundentabelle in der Uhr und Suunto App✔
Durchschn. max. Rundentempo in Echtzeit✔
Intervallführung mit Laufgeschwindigkeit/Herzfrequenz/Distanz✔
MULTISPORT
Sportmodus während des Trainings wechseln✔
Vorkonfigurierte Multisport-Modi✔
Nachanalyse der Multisport-Übung nach Sportart✔
Multisport-Übungszusammenfassung auf der Uhr✔
SPORTMODI
Anpassbare Sportmodi und Anzeigen✔
Grafische Anzeigen in Sportmodi✔
Vorgefertigte Sportmodi auf der Uhr> 90
SuuntoPlus™✔
TAUCHFUNKTIONEN
FREITAUCHEN
Tiefenmesser für Schnorcheln10 m
