Suunto-blogg
How to find your way in the mountains
The more people in the group who can navigate confidently the safer it is. © Arc'teryx / Piotr Drozdz Knowing how to read a map, use a compass and find a safe route through the mountains are essential outdoor skills for hikers, climbers, mountain bikers and trail runners. These skills, the basis of good wayfinding, make our adventures safer and more enjoyable. In this series of articles, Terho Lahtinen, who works in Suunto’s Emerging Business team, will explain how to develop these essential mountain navigation skills. Terho was lead navigator in an adventure racing team that competed all over the world for eight years. He recently led a clinic on wayfinding at the Arc'teryx Alpine Academy, and helped dedicated adventurers gain greater confidence on their trips. “The confidence that comes from knowing how to navigate in the mountains helps you to relax on their trips, making them more enjoyable,” Terho says. “Location awareness, map reading and compass orientation are also fun in of themselves.” In this first article of the series, Terho explains where to begin to develop your wayfinding ability. Don't be dependent Yes, it’s true we have GPS nowadays, but digital navigation technology isn’t a replacement for these essential skills; as we explain below, mobile phones and GPS devices should play a support role only. What happens, for example, if your smartphone runs out of batteries or falls in a river? What if the reception sucks? Or you are dependent on someone in your group to be the navigator and he or she gets it wrong? The more people who know how to navigate the safer the group. Even if you usually follow well marked trails, knowing how to navigate with a map and compass can come in handy. A few moments of distraction while passing a fork in the path, and you could go in the wrong direction and an hour or so later find yourself wondering where the heck you are. It happens. Location awareness is key It all starts here. Without this ability, the other skills will be shaky. Location awareness is more than just knowing where you are. “It’s an attitude of consciously and constantly observing things around us and a sensitivity to notice the essential landmarks,” Terho explains. “It’s almost an intuitive feeling for the landscape around you.” This honed sense of location awareness makes orientation more straight forward. Orientation is the attempt to determine one’s location by relating your position to nearby objects or landmarks. This depends on being able to relate what you see around you to what you see on a map. It takes time to develop this, but with regular practice it will come. Start observing To cultivate location awareness, learn to be more observant. “Start observing things around you, studying maps, correlating map information and the real world to each other, and it gets more and more interesting every day,” Terho says. “If you are using phone apps for navigation, stop using automatic guidance and just use your location on the map, choose the way yourself, and study what’s around you and how it appears on the map or a satellite image.” The more you use topo maps, the more you’ll come to love them. © Arc'teryx / Piotr Drozdz Practice with topographical maps We all agree that Google Maps is possibly the next best thing to sliced bread. It is immensely helpful when running late for an appointment while navigating in an unfamiliar city, for example. But digital technology has its limitations, too. We should avoid becoming dependent on it. Terho suggests buying a topographical map of an area you know well and start studying the map and relating what you see around you. Doing this over time will give you a sense of how maps communicate land formations. “Paper maps never run out of batteries and they won’t break if they fall on the ground,” Terho says. “They contain much more detailed terrain information than most digital maps and are much more practical for planning and for studying larger areas and longer routes.” Learn the contours The number one thing to learn is correlating contour lines on the map and topographic shapes in your surrounding landscape to one other. The map should tell you what you can expect to see around you. With time and practice, you get a feeling for this. “Contour lines describe the shape of the earth’s surface and that’s the most important information on any map for outdoor activities,” Terho says. “Studying maps at home is a great exercise for getting the feeling, comparing map and actual terrain is even better.” Practice makes perfect In each article of this series Terho will suggest some homework for you to do to cultivate your wayfinding skills. This first article’s homework will keep you busy! Map study Get a terrain map for an area you know well (where you won’t get lost). Study the map at home, spot familiar places on the map and find out how they are illustrated. Compare the map with your memory of those locations. Terrain recognition Remember your latest activity in the map area and identify your route on the map. Study the contours lines and look at the intervals between them. Where are the hills? How high are they? Are there any valleys, ridges, gorges, or saddles? Is the slope in a specific location steep or flat? What is the highest point on the map? The lowest? Where is the steepest slope? Field study Time to take the map into the field. When you’re out there, align the map with the surrounding terrain (north on the map pointing to the north in the terrain). Look around at what you see and compare it to your map. This can be visualized by imagining the map is fixed to north and you are walking around it, depending on which direction you are going to or looking at. If you are looking south, you are on the north side of the map and north on the map is pointing at you. When changing direction, you are turning, not the map. You are always holding the map in front of you and the map is pointing to north. Now, choose a route that you’re familiar with. Follow your progress on the map, and spot every detail that’s drawn on the map and identify them in the terrain. This is a great way to learn how the map and the terrain relate to each other. Panoramic view Find a spot where you have a sweeping view of the landscape. Keep the map aligned, north pointing north, with the terrain. While looking in different directions, find distinctive terrain features, such as cliffs, peaks, valleys, buildings, and rivers and then locate them on the map. Guide a buddy Head into familiar hills with a friend. Make a route plan in advance, explain the plan to your friend including the different terrain features and other objects you are going to use for navigation waypoints. While out there, explain all the things you observe in the terrain and show where they are on the map. Then let your friend do the same. Stay tuned for the next article in the series: how to plan your route through the mountains! Lead image: © Arc'teryx / Piotr Drozdz Read more articles: 7 tips to find a safe track up the mountain 8 avalanche safety checks to tick off before the ski season Born to shred in the Arctic Proving electric adventure is the future
SuuntoClimb,SuuntoRide,SuuntoRun,SuuntoSkiDecember 11 2019
Get ready to race with our trail marathon training plan
Nicknamed the “marathon whisperer” Denise Sauriol knows the distance inside out. She should do after running more than 112 marathons in locations across all seven continents. She is one of our Suunto multisport team coaches and has designed this plan for trail runners. Denise began running as a child and ran her first marathon in 1994. She continued advancing as a marathoner until August 2009. She was running to Central Park to race in the New York Half Marathon, but never made it to the start line. A car struck her, breaking five of her vertebrae, and temporarily ending her running career. To give back to the sport she loves dearly, she transitioned to coaching. “I loved coaching so much that in 2016 I left my 26-year career to become a full-time running coach,” she says. “I have a lot of practice on what to do and what not to do with training and on race day. I coach runners of all abilities, ages and race goals. I have helped my clients run their first mile, all the way to helping some of them run a 100 mile ultra.” Click here to access Denise’s 20 week trail marathon training plan! Ready to train? Let coach Denise guide you! Denise has created a 20 week trail marathon training plan for beginners. Available for download on Training Peaks, it’s designed for runners who are already averaging between 32 and 40 km per week and can comfortably run a 12 to 16 km long run each week. It assumes people following it have a strong endurance base. The plan has a four week cycle: In the first three weeks the volume and long run distance increase by 10% each week. Then both decrease on the fourth week. This ensures a balance of build up and recovery time. The training volume continues increasing up until two 32 km long runs. This gives athletes plenty of time on their feet and more confidence than if they only complete one 32 km long run. “The plan also allows for a three week taper,” Denise says. “During the taper the volume drastically decreases, allowing the body and mind to rest and reset for race day.” Denise advises athletes following her plan to make sure they do their long runs on trail, not on roads or treadmills. She says this is one of the most common mistakes she sees trail runners make. “You have to train on trails to race trails,” she says. “Trail running is a different beast than road running. You can run some of your training miles on a treadmill or on the road, but I recommend a high percentage of your weekly miles, especially the long runs are run on trail.” The plan is available for free as part of Suunto Value Pack via TrainingPeaks, one of Suunto’s key partners, and provides easy to understand, week-by-week, session-by-session, training guidance. Your end of the bargain is doing the work. To download Denise’s 20 week training plan, login or sign up to TrainingPeaks and find the plan here. LEARN MORE ABOUT SUUNTO VALUE PACK AND HOW TO GET THIS TRAINING PROGRAM FOR FREE
SuuntoRunDecember 09 2019
Welcome to Suunto Summit!
The fifth instalment of Suunto Summit, a celebration of our community and our collective passion for sport and the outdoors, will be held in January 2020 in Ylläs, in Finnish Lapland. We will start the weekend with a visit to Suunto factory and Suunto HQ in Vantaa and then travel by an overnight train to Ylläs, north of the Arctic Circle, to experience the beauty of northern Finland. The participants for Suunto Summit 2020 are: Alberto from Spain, Alexandre from Brazil, Alpinefex from Germany, Dorn from USA, Lotta from Finland, Maja from Sweden, Majo from Philippines, Marie from UK, Matteo from Italy, Max from USA, Philipp from Germany, Sandra from Australia, Sawna from USA, Thumb K from Korea, and Xiaohua from China. Welcome to Suunto Summit! Thank you to all who applied! We are humbled to have such a passionate community. It was very inspiring to hear your stories and to get to know you a little bit. Happy adventures and hope to meet you another time!Excitement at the 2018 Suunto Summit. Watch the event recap here
SuuntoRide,SuuntoRun,SuuntoSkiNovember 26 2019
Celebrating the fall of the wall by running the “death strip”
© Philipp Reiter Suunto athlete and filmmaker Philipp Reiter and eight other runners from Germany and Austria are setting out on November 1 to run the once feared militarized border – called the “death strip” by west Germans – that divided east and west Germany from 1952 to 1990. “We have four campervans and runners of all different ages and originally from both sides of the former border,” Philipp says. “I know the history of the border from school, but if you are not born in that time, you don’t really understand what it was like then,” he says. “I think it’s going to be really nice learning about this.” The 1400 km adventure run will include 16,000 m of vertical gain and the highest point on the route is the summit of Brocken, a 1142 m peak in the Harz Mountain Range. The team will run it as a relay, with one athlete running 15 km before the next steps in and takes over. Most of the route will be on quiet forest roads. They are inviting local runners in towns and villages they pass through to follow their journey on Strava and to join them when they are nearby. Philipp is interested to hear the stories of people who lived during the time of the border. “This project is about showing that even if it takes 40 years, there is always an opportunity to take borders down, even now,” he says, “These borders can be physical like this one, or they can be in the form of prejudices. How many people really try to understand the problems of another person?” Map showing the former border, now called the Green Belt. And the remains of the Berlin Wall. © LENCER (CC BY-SA 3.0) © Photo by Isai Ramos on Unsplash The inner German border, part of the Iron Curtain, stretched from the Baltic Sea to the former Czechoslovakia. The Berlin Wall was only a smart part of it. West Germans called it the “death strip” because it was so perilous to cross. The borderzone was fortified with trip-wire machine guns, more than a million landmines, 3000 attack dogs and guards with orders to shoot to kill. In spite of this, thousands of people risked their lives trying to escape the totalitarian German Democratic Republic in the east for a better life in the Federal Republic of Germany in the west. Hundreds of them died in the process. Since the fall of the wall, the borderzone has been demilitarized, and is now a popular area for cycling and walking. Thanks to a conservation project led by BUND Naturschutz what was once a “monument to repression” has been transformed into a “symbol of renewal”. Now called the Green Belt, the former border is a hotspot for wildlife. This year marks the 30th anniversary of the fall of the Berlin Wall. Starting on November 4, there will be events and exhibitions across the city. Follow Philipp and the team’s journey here on Strava. This run is recorded using Suunto 9 watches. Learn more about them here.
SuuntoRunOctober 31 2019
7 tips for running in the dark
© Dean Leslie / Red Bull Content Pool As the northern hemisphere heads into winter, Ryan Sandes’s hometown, Cape Town, is coming out of it. He recently ran his new 13 Peaks route, starting at 3am, and had an eerie feeling that someone was watching him. “I looked around and there were all these little eyes looking at me from out of the darkness,” he says. “They were rock rabbits.”  Ryan has run in the dark in some gnarly places. He says it’s completely different to running in the day. “Running in the dark is a bit like running downhill – you have to be careful,” he cautions. Here are 7 tips to better enjoy running at night or early morning. Stay safe Tell someone where you are going and when you plan to be back. This is especially important if you are heading out for a trail run in the wild. Consider taking a tracking device, too. If you get disoriented or lost, remember you can use the Find Back feature and breadcrumb route on your Suunto 9 watch to be led back to your start point. Make yourself visible Buy yourself an assortment of reflectors for your clothing so you are clearly visible to cyclists and drivers from a distance. Use “biological motion” for increased visibility; this means lighting up your joints – ankles, knees, wrists and elbows, not the torso – so motorists and cyclists recognise you as a moving person. Slow down If you’re new to running in the dark, Ryan suggests slowing down until you get used to it. “The more you practice, the better you’ll get,” he says. Master your headlamp Wearing a headlamp is essential if you’re running in an area with no streetlights. Learning to focus and point the beam correctly takes some fiddling; best to test this at home before heading out. Aim the lamp so the beam illuminates the area about 10 m or so out from you, and make sure the light isn’t too focused or it can give you “tunnel vision”. Learn to adjust the settings while you’re running to preserve battery life. “If you’re going downhill really fast you will need to have it brighter and with a bigger beam,” Ryan says. “If you are going uphill slowly you can turn it down.” Look ahead, not down Having the right head position is important. “Don’t drop your head and start looking at your feet because that automatically slows you down,” Ryan says. “Look ahead, and your brain will programme where your feet will go before they get there.” Pick your lines With the correct head position and beam focus, it makes it easier to see the contours of the terrain and coming obstacles. Staying focused, not spacing out, is essential when running in the dark. “Try to pick right lines [to follow] when you’re running so you can keep moving,” Ryan says. “You don’t want to lose concentration and end up going over a bunch of rocks, or scrambling through the bush.”    Enjoy the atmosphere “Running in the dark gives an almost out of body experience,” Ryan says. “Everything is really peaceful, you can hear all the little sounds, everything seems fresher, and you become a lot more aware. Enjoy it!” Lead images: © Craig Kolesky / Red Bull Content Pool © Graeme Murray / Red Bull Content Pool Read more running related articles! 7 principles to help you find the flow The lazy runner's guide to a marathon Emelie Forsberg's 7 yoga poses for runners 7 tips for running in hot weather
SuuntoRunOctober 22 2019
Hunter or the hunted? 7 race tactics for the trophy
Both of them know the feeling of being hunted. It’s when they’ve been in first place, and there’s a pack of wolves at their heels. “When you are leading a race you often feel like a hunted animal,” Ryan says. “You are always looking behind you, are you going too fast, are you going slow enough, are the guys catching you? Mentally, that is super draining. Sometimes hunting is better than being hunted.” Ryan, an ultra running champion, has felt invincible during some races, and that his competitors were “dead and buried”, only for them to suddenly catch up and pass him. Mel has literally run shoulder to shoulder against another triathlete for 15 km, in what she says “felt like an eternity”. In the last three kilometers she turned it on and left her rival in the dust. “I started sprinting and not looking back,” Mel says. “It turns out she didn’t even try to come with me, but I didn’t turn around to check. I just kept pushing right to the line. “The smarter and easier move would have been to sit in (behind) and wear my competitor down that way, but for some reason we both thought we needed the mental battle of running side by side for most of the run. Not a single word was spoken between us during this hour long battle. After the race, we both shared a laugh and commented on how much we made each other suffer out there. “ Here are Mel and Ryan’s seven tips for victory. © Kelvin Trautman / Red Bull Content Pool Keep a poker face Both of them recommend putting on a brave face. Show your rivals nothing. “Control your breathing and keep good form at least when they can see you,” Mel says. “Make it look easy. Don’t make eye contact with your rivals.” Stay to your strengths Don’t try to run your rival’s race. “The key strategy is to run to your strength,” Ryan says. “If you're slightly better on the climbs, push them a little bit, so then your competitor has to push the downhills to catch up, smashing his legs in the process. It's all about trying to feel your competitor out, seeing what their weaknesses are, compared to your strengths.” Remember, they hurt too Feeling the pain? Quads burning? That’s because you’re human, and your rivals are, too. “I know if I’m hurting so are my competitors so I stay focused and imagine them struggling and working hard,” Mel says. “That gives me a little confidence boost.” Mind game your rival Watch your rival closely. If he or she is struggling, accelerate. “When you think they’re feeling bad, start talking to him or her with your poker face on, pretending you’re feeling good,” Ryan suggests. “It’s a bit of a game of roulette; sometimes it pays off, other times it doesn’t.” Training is your dojo Training is when you test your mettle. It’s when you develop the tenacity and forbearance you’ll need to survive your race battles. “Never give up in training,” Mel says. “When I’m really hurting in training, I imagine I’m in a race situation and that if I back off now or give up, I’ve just lost the race. The more times you throw in the towel in training the harder it will be to push through the pain in a race.” Ryan recommends working on your weaknesses in training. “If descending isn’t a strength for you, work on it,” he says. And when you’re training, run at different intensities.” Learn to adapt While it’s necessary to have a race plan, remember whatever your plan is, no matter how slick it is, on race day it will probably go out the window. “It’s so important to keep your mental focus and stay calm and collected,” Ryan says. “The person who is the most successful in a race is the one who can think the best on his or her feet and go with the flow.” Kindness can pay off Yes, racing is about winning. But that doesn’t always demand a ruthless attempt to crush the opposition. Sometimes a little camaraderie and kindness can go a long way. “If a competitor is struggling, for example when they need nutrition or a cold sponge, if I have the energy to help out I will because this not only helps them, but it also helps me,” Mel explains. “Helping someone makes you feel good and when you feel good you race better. This is a great way to get a little lift.” Lead images: © Craig Kolesky / Red Bull Content Pool © Kelvin Trautman / Red Bull Content Pool Read more: The art of battle: six tactics to slay your competitors
SuuntoRunOctober 17 2019
