Sold out
1 / 3
Suunto D5 Copper
Suunto D5 Copper
Suunto D5 Copper
1/3
Money-back guarantee
30-Days Return
Global Support
SKU: SS050569000
Suunto D5
Copper
Sale price2.132 zł
An easy-to-use dive computer with interchangeable straps that fit your style. Made in Finland.
Choose your Color
Quantity
30-Days Return
Global Support
Suunto D5 Copper
2.132 zł
Sold out
Wireless tank pressure support
Extensive scuba and freedive features
Digital compass
Wireless mobile connection
Vibration alarms
Rechargeable battery
iF Design Awards 2020
Diving life made easy
Suunto D5 is designed to be so clear and easy-to-use that you can just enjoy and focus on exploring the wonderful underwater world. When not diving, connect wirelessly to Suunto app and receive notifications from the applications you use. Play with style by choosing your favorite color or just by simply changing the straps to match your looks. Suunto D5 connects your two lives: the adventure under the surface but also the great experiences you can relive and share with your friends afterwards.
BENEFITS
EASY TO USE
Follow your dive details on the super clear, high contrast color screen. Choose from 3 dive modes and browse the simple yet intuitive menu with three buttons to easily switch between views and settings. You can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. Keep your device easily up-to-date with SuuntoLink and make your dive life one step easier.
DIVING LIFE MADE EASY
Pair your Suunto D5 with Suunto app and stay connected with the diving community and the non-diving life of yours. Receive notifications to your mobile of the applications you use and never miss an adventure.
Transfer your dive logs over Bluetooth to build an all-inclusive dive history to relive and share with your friends. With the location feature every dive and adventure is always on the map.
Suunto app is available in the App Store and Google Play.
MATCH WITH YOUR STYLE
Change the strap easily with the clever quick release system to fit your style. Choose a color that matches your diving gear, or pick your favorite color silicone or leather strap to complete your casual style. To support your everyday usage, an analog watch face is now available for those appreciating the classic style.
WIRELESS CONNECTIVITY
Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto D5 with the Suunto Tank POD before diving. After dive review your gas consumption (when using Suunto Tank POD) in Suunto app and improve your diving.
ХАРАКТЕРИСТИКИ
  • Размеры
    53 x 53 x 16.3 mm / 2.09 x 2.09 x 0.64 "
  • Вес
    90 g / 3.17 oz
  • Материал безеля:
    Stainless steel
  • Материал стекла:
    Mineral crystal
  • Материал корпуса:
    Reinforced composite
  • Материал ремешка:
    Silicone
  • Комплектация
    Suunto D5 Copper, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet, Suunto sticker
  • Страна производства
    FI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
  • Материал безеля
    Stainless steel
  • Материал стекла
    Mineral crystal
  • Материал корпуса
  • Материал ремешка
    Silicone
  • Вес
    90 g / 3.17 oz
  • Виброоповещение
  • Водостойкий
    100 m (ISO 6425, EN 13319)
  • Тип батареи
    rechargeable lithium-ion
  • Обновляемое встроенное ПО
  • Время, дата
  • Будильник
    1 daily alarm
  • Время для двух часовых поясов
  • Секундомер
  • Языки
  • Подсветка
    LED
  • Настраиваемая подсветка
  • Тип дисплея
    Memory in pixel
  • Разрешение дисплея
    320 x 300
  • Метрическая и британская системы измерения
  • Индикатор заряда батареи
    icon + dive hours remaining
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
  • Рабочая температура
  • Температура хранения
  • Рекомендуемая температура зарядки
BATTERY LIFE
  • Battery life (dive)
    up to 6-12 h of diving fully charged or up to 6 days in time mode
КОМПАС
  • Цифровой компас
  • Компенсация склонения
    up to 45°
  • Коррекция склонения
  • Шкала направления
    degrees
  • Стрелка
    compass rose
  • Фиксация азимута с индикатором направления
  • Глобальная балансировка
  • Точность компаса
    +/- 15°
  • Дискретность компаса
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
  • Возможности подключения (между устройствами)
    inductive (Tank POD), Bluetooth Smart
  • Совместимо с приложением Suunto
  • Индивидуальная настройка часов
    Customizable with DM5
  • Уведомления телефона на часах
  • Совместимость с DM5
  • Передача журнала
    Bluetooth Smart / USB cable
  • Совместимость со смартфонами
    Most common models supported
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
ПОГОДА
  • Термометр
  • Диапазон отображения температуры
    -20 to +50 °C/-4 to +122 °F
  • Дискретность температуры
    1° C / 1.5° F
ФУНКЦИИ ДЛЯ ПОГРУЖЕНИЯ
БАЗОВЫЕ ВОЗМОЖНОСТИ
  • Поправка по высоте
  • Отображение времени всплытия
    0 - 999 min ( > after 999)
  • Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения)
  • Настраиваемые режимы погружения и дисплеи
  • Модель декомпрессии
    Suunto Fused™ RGBM 2
  • Декомпрессионная остановка
  • Журнал погружений
    lifetime
  • Время погружения
    0 to 999 min
  • Фридайвинг
  • Потребление газовой смеси (в реальном времени)
  • Максимальное парциальное давление кислорода (pO2) в дыхательной смеси
    1.6
  • Время по газовой смеси
  • Газовые смеси
  • Gauge (Датчик)
  • Создание ярлыков журнала
  • Память для журнала измерений
  • Изменение интервалов регистрации данных в журнале
    scubadive 10s, freedive 1s
  • Максимальная глубина погружения (EN 13319)
  • Кислородно-азотная смесь (и воздух)
  • Время запрета полетов
  • Планировщик бездекомпрессионного предела
  • Персональная настройка
    P+2, P+1, P0, P-1, P-2
  • Остановка безопасности
  • Время на поверхности
    0 to 100 h
  • Таймер
  • Визуальный стиль
    Graphical
  • Беспроводное подключение к системе подачи воздуха
    optional (up to 3 different tanks with Suunto Tank POD)
СИГНАЛЫ И УВЕДОМЛЕНИЯ ПРИ ПОГРУЖЕНИИ
  • Вычисление ЦНС (%) + ед. токсичности кислорода (коэффициент предельного насыщения) 80% / 100%
  • Выход за верхний декомпрессионный предел
  • Выход за точку глубокой остановки
  • Время погружения
  • Высокое парциальное давление pO2 (гипероксия)
  • Переключение газовой смеси (на более подходящую, если имеется)
  • Давление в баллоне
  • Слишком быстрое всплытие
ФРИДАЙВИНГ
  • Оповещение о глубине
  • Уведомление о глубине
    yes (5)
  • Уведомление о времени на поверхности
  • Дневной журнал фридайвинга
  • Количество свободных погружений
  • Общий журнал фридайвинга
    lifetime
Recommended products
VIDEOS
You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
Learn how to set depth notifies and a surface notify to use Suunto D5 for advanced free diving.
Learn how to pair your Suunto D5 with the Suunto app for Android and how to get started with the app.
Learn how to pair your Suunto D5 with the Suunto app for iOS and how to get started with the app.
Learn how to use the compass bearing of your Suunto D5.
DM5 is Suunto’s desktop software to customize and update the firmware of your dive computer. DM5 offers various customization options for Suunto D5.
SUPPORT FOR SUUNTO D5
