Suunto A-10
SH Compass
A robust, easy to use compact compass for general recreational use.
Choose your Color
MINIMALISTIC BASEPLATE COMPASS FOR HIKERS AND SCOUTS
Fast, simple and accurate, A-10 baseplate compasses are quick to learn and ideal for navigating with a map and compass. For calculating the distances, A-10 has both metric and empirical scales printed in red to stand out on topographic map.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To overcome this, A-10 has two variants with needles balanced for either the northern or southern hemisphere.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
ХАРАКТЕРИСТИКИ
Размеры56 x 104 x 10 mm / 2.2 x 4.09 x 0.39 "
Вес30 g / 1.06 oz
Материал безеля:Plastic
КомплектацияSuunto A-10 SH Compass, lanyard, Quickrelease, Quick Guide
Страна производстваFI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляPlastic
Metric scalesсм с навигаторами дистанции
Imperial scalesдюймов с помощниками дистанции
Declination correctionфиксированная шкала
Balanced for southern hemisphere✔
Вес30 g / 1.06 oz
Водостойкийinsensitive to water pressure
Тип батареиno battery required
Быстросъемное крепление шнурка✔
Креплениешнурок
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-30° C to +60° C / -22° F to +140° F
Температура хранения-30° C to +60° C / -22° F to +140° F
КОМПАС
Шкала направленияdegrees
Стрелкаhigh grade steel
Фиксация курса с индикатором ориентирования✔
Жидкостный, сапфировые опоры осей✔
Точность компаса2.5°
Дискретность компаса2°
