1 / 4
Suunto Ambit3 Peak Sapphire Blue (HR)
1/4
Money-back guarantee
30-Days Return
Global Support
SKU: SS022305000
The GPS watch for multisport athletes and explorers with heart rate monitoring
30-Days Return
Global Support
€999
Sold out
CLASSIC ADVENTURE COMPANION
Whether you’re reaching for the top of the summit or a new personal best, Suunto Ambit3 Peak will be there to help you. A GPS watch designed for adventures that reach the edges of the map, it provides everything you need to find your way, stay safe and follow your progress.
KEY FEATURES
LONG BATTERY LIFE
GPS NAVIGATION
BAROMETER FOR ALTITUDE ACCURACY
WEATHER FUNCTIONS
100 M WATER RESISTANT
10 SPORT MODES
DIGITAL COMPASS
UPDATABLE SOFTWARE
“This thing has proven itself to be of incredibly high quality.”
All Day Ruckoff
"The Suunto Ambit3 Peak represents the latest in wearable technology."
Gear Institute
"The battery life on the Ambit3 Peak is also simply outstanding."
Phil the Runner
BENEFITS
Right tools for the outdoors
Accurate altitude measurements are delivered by FusedAlti, which combines GPS with barometric altitude. The barometric trend predicts changes in weather and the storm alarm lets you know when it’s time to find shelter. Sunrise and sunset times keep you informed of remaining daylight hours.
Adventure-proof
Looking to go off the grid or on a longer journey? Suunto Ambit3 Peak comes with up to 200 hours of battery life with the GPS turned on that lets you explore longer. Designed for durability, you can rely on it on your treks off the beaten path. It’s also water resistant up to 100 meters.
Read more about Suunto app
Sports tracking essentials
Keep track of your exercises, progress and recovery with ten customizable sport modes and detailed information on your exercises. You can also connect your watch to Suunto app and view your exercises there or take advantage of Suunto’s wide network of partners to access more features and training tools.
ХАРАКТЕРИСТИКИ
  • Размеры
    50 x 50 x 17 mm / 1.97 x 1.97 x 0.67 "
  • Вес
    92 g / 3.25 oz
  • Материал безеля:
    Steel
  • Материал стекла:
    Sapphire crystal
  • Материал корпуса:
    Polyamide
  • Материал ремешка:
    Silicone
  • Комплектация
    Suunto Ambit3 Peak Sapphire Blue, Suunto Smart Sensor and blue heart rate belt (size M), USB cable, quick guide, warranty leaflet
  • Страна производства
    FI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
  • Материал безеля
    Steel
  • Материал стекла
    Sapphire crystal
  • Материал корпуса
    Polyamide
  • Материал ремешка
    Silicone
  • Вес
    92 g / 3.25 oz
  • Водостойкий
    100 m
  • Тип батареи
    rechargeable lithium-ion
  • Обновляемое встроенное ПО
  • Время, дата
  • Будильник
    1 daily alarm
  • Время для двух часовых поясов
  • Автоматический хронометраж
  • Таймер обратного отсчета
  • Секундомер
  • Языки
  • Подсветка
    LED
  • Настраиваемая подсветка
    brightness / mode
  • Блокировка кнопок
    customizable
  • Инверсия изображения
  • Тип дисплея
    matrix
  • Разрешение дисплея
    128 x 128
  • Метрическая и британская системы измерения
  • Индикатор заряда батареи
    percentage / icon
  • Автоматическая прокрутка экранов тренировок
  • Индикатор объема доступной памяти
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
  • Рабочая температура
  • Температура хранения
  • Рекомендуемая температура зарядки
BATTERY LIFE
  • In time mode
    30 days
  • Training mode with GPS
    20, 30, 200 h For more information www.suunto.com/software-updates
КОМПАС
  • Цифровой компас
  • Компенсация склонения
    full
  • Коррекция склонения
  • Шкала направления
    degrees / mils
  • Стрелка
    north indicator
  • Фиксация азимута с индикатором направления
  • Точность компаса
  • Дискретность компаса
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
  • Возможности подключения (между устройствами)
    Bluetooth Smart
  • Индивидуальная настройка часов
    USB cable
  • Передача данных
    Wireless / USB cable
  • Уведомления телефона на часах
    with Suunto App
  • Поддержка спортивных онлайн-сообществ
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
  • Совместимость со смартфонами
    iPhone, Android
ПРИЛОЖЕНИЯ SUUNTO APPS
  • Совместимо с устройствами Suunto Apps
  • Макс. кол-во приложений в спортивном режиме
    5
  • Регистрация показателей по приложениям
  • Наиболее рекомендуемые приложения в зависимости от вида спорта
  • Создание собственный показателей при помощи усовершенствованных формул
  • Хронометр, GPS, данные о частоте сердцебиения, погоде и высоте над уровнем моря
  • Данные о беге, езде на велосипеде, плавании
  • Обширный набор математических функций, условные операторы «если... то», звук, подсветка и т. п.
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
  • Спутниковые системы
    GPS
  • Интервал регистрации GPS
    1, 5, 60 s
  • Различные системы координат
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Навигация по путевым точкам и визуальная навигация по маршруту
  • Макс. кол-во интересующих пунктов (POI)
    250
  • Поиск дороги назад
  • Планирование маршрутов с профилем высот
  • Навигация по профилю высоты маршрута в режиме реального времени
  • Пункты маршрута в маршруте / POI в часах
    1000 / 250
  • Анализ маршрута по данным GPS
  • Функция обратного пути
    yes
  • Параметры, просмотр и экспорт маршрутов
    in Suunto App
  • Планирование маршрута
    in Suunto Movescount.com
АЛЬТИМЕТР
  • Барометрический альтиметр
  • График высот над уровнем моря
  • Высота по данным GPS
  • Объединение данных GPS с данными барометрического альтиметра (FusedAltiTM)
  • Перепад высот над уровнем моря
    yes** ** available as Suunto Apps
  • Общий подъем/спуск
    air pressure based
  • Вертикальная скорость
    air pressure based
  • Автопереключение профиля высотомера и барометра
  • Интервал регистрации в журнале
    1, 10 s
  • Дискретность
    1 m
  • Диапазон
    -500 - 9999 m
ПОГОДА
  • Время восхода/захода солнца
  • Штормовое предупреждение
  • Атмосферное давление
  • Термометр
  • Диапазон отображения температуры
  • Дискретность температуры
  • Дискретность давления
    1 hPa / 0.03 inHg
  • Макс. продолжительность регистрации погоды
    past 26 hours
  • График изменения атмосферного давления
  • Информация о приливах
  • Индикатор прогноза погоды
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ЧАСТОТА СЕРДЦЕБИЕНИЯ
  • Интервал RR
  • Частота сердцебиения в удаках в минуту
  • Запись сердечного ритма при плавании
  • График частоты сердцебиения в режиме реального времени
  • Калории
    1, 10 s
  • Максимальная эффективность тренировки
  • Время восстановления
  • Руководство во время тренировки на основании скорости и частоты сердцебиения
  • Текущая, средняя и максимальная частота сердцебиения
  • Показатель EPOC в режиме реального времени
  • Частота сердцебиения в % от макс. ЧС
  • Предельные значения частоты сердцебиения
СКОРОСТЬ И РАССТОЯНИЕ
  • Скорость и расстояние по данным GPS
    Integrated
  • Хронограф
  • Поддержка Foot POD
    Bluetooth Smart
  • Поддержка Bike POD
    Bluetooth Smart
  • Расстояние на основе автоматического отсчета этапов
  • Этапы
    > 1000
    1, 10 s
  • Автоматическая пауза
ВОССТАНОВЛЕНИЕ ПОСЛЕ ТРЕНИРОВОК
  • Быстрый тест восстановления (Firstbeat™)
  • Тест восстановления во время сна (Firstbeat™)
  • Время восстановления в зависимости от тренировок
НАГРУЗКА ПРИ ТРЕНИРОВКЕ
  • Сводка из журнала в часах с информацией по этапам
  • Анализ тренировок
    in Suunto App
  • Журнал тренировок с поддержкой текста и изображений
    in Suunto App
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ПЛАВАНИЕ
  • Темп и расстояние заплыва в бассейне
  • Темп и расстояние заплыва в открытой воде
    Yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
  • Время плавания: длина дорожки, этап, общее
  • Частота гребков, количество и тип
  • Эффективность гребков (SWOLF)
  • Автоматические интервалы
  • Определение стиля плавания с обучением персональному стилю
ЕЗДА НА ВЕЛОСИПЕДЕ
  • Скорость езды
  • Средняя скорость в режиме реального времени
  • Мощность езды на велосипеде (Вт), средняя и максимальная (с датчиком мощности)
    Bluetooth Smart
  • Bike Lap and Lap Maximum Power (с датчиком мощности)
  • Аэродинамическое сопротивление в режиме реального времени (с ANT+ датчиком мощности)
  • Мощность езды на велосипеде за 3 с, 10 с, 30 с (с датчиком мощности)
  • Поддержка Cadence POD
    Bluetooth Smart
  • Подъем в гору в режиме реального времени
    yes, available as Suunto Apps
  • Поддержка нескольких устройств Bike POD
  • Нормализованная мощность (Suunto Apps / TM от Training Peaks)
БЕГ
  • Темп бега
  • Suunto FusedSpeed™
  • Мощность бега
    with Stryd sensor
  • Калибровка Foot POD
    manual or GPS
  • Средний темп в режиме реального времени
  • Сравнение этапов по километрам/милям
  • Оценка времени завершения марафона
  • Средняя длина большого шага
  • Темп бега
    watch or Foot POD
  • Эффективность бега (с технологией Firstbeat™)
ТРЕНИРОВКИ С НЕСКОЛЬКИМИ ВИДАМИ СПОРТА
  • Изменение спортивного режима во время тренировки
  • Настроенные режимы для тренировок с несколькими видами спорта
  • Пост-анализ многоборья по видам спорта
СПОРТИВНЫЕ РЕЖИМЫ
  • Настройка спортивных режимов и дисплеев
    10 modes / 8 displays per mode
Recommended products
Support for Suunto Ambit3 Peak
