1 / 5
Suunto Ambit3 Vertical Black
1/5
SKU: SS021965000
The multisport GPS watch for planning and tracking your elevation gain
€947,26
Sold out
The vertical experience for multisport
Some call it obsession, we call it dedication. The Suunto Ambit3 Vertical is more than just a multisport GPS watch. Follow the altitude profile of your route while working your way up mountains. Keep track of your total vertical gain from your yearly total to day-by-day ascents.
PRODUCT HIGHLIGHTS
  • The GPS watch with advanced training and recovery functions
  • Plan and track your elevation gain with ease
  • Relive and share your experience
Best New Gear Award: Outdoor Retailer Winter 2016
Gear Institute
Best in Show: Outdoor Retailer Winter 2016
Gumption Gear Review
Editor's Choice 2016 Award
Competitor magazine
"The name says it all. It’s everything but the kitchen sink for the vertically minded runner, cyclist and triathlete."
Competitor.com
"It's refined design is fantastic, making it both thinner and lighter, while its ability to track 3D movement is sure to make it a hit with serious outdoor athletes too."
Gear Institute
"While few of us may dream of conquering Mont Blanc, the Ambit3 Vertical is the tool we’d take along if we tried."
Runners' World
ХАРАКТЕРИСТИКИ
  • Размеры
    50 x 50 x 15 mm / 1.97 x 1.97 x 0.59 "
  • Вес
    74 g / 2.61 oz
  • Материал безеля:
    Steel
  • Материал стекла:
    Mineral crystal
  • Материал корпуса:
    Polyamide
  • Материал ремешка:
    Silicone
  • Комплектация
    Suunto Ambit3 Vertical Black, USB cable, quick guide, warranty leaflet
  • Страна производства
    FI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
  • Материал безеля
    Steel
  • Материал стекла
    Mineral crystal
  • Материал корпуса
    Polyamide
  • Материал ремешка
    Silicone
  • Вес
    74 g / 2.61 oz
  • Виброоповещение
  • Водостойкий
    100 m
  • Тип батареи
    rechargeable lithium-ion
  • Обновляемое встроенное ПО
  • Время, дата
  • Будильник
    1 daily alarm
  • Время для двух часовых поясов
  • Автоматический хронометраж
  • Таймер обратного отсчета
  • Секундомер
  • Языки
  • Подсветка
    LED
  • Настраиваемая подсветка
    brightness / mode
  • Блокировка кнопок
    customizable
  • Инверсия изображения
  • Тип дисплея
    matrix
  • Разрешение дисплея
    128 x 128
  • Метрическая и британская системы измерения
  • Индикатор заряда батареи
    percentage / icon
  • Автоматическая прокрутка экранов тренировок
  • Индикатор объема доступной памяти
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
  • Рабочая температура
  • Температура хранения
  • Рекомендуемая температура зарядки
BATTERY LIFE
  • In time mode
    14 days
  • Training mode with GPS
    10, 15, 100 h For more information www.suunto.com/software-updates
КОМПАС
  • Цифровой компас
  • Компенсация склонения
    full
  • Коррекция склонения
  • Шкала направления
    degrees / mils
  • Стрелка
    north indicator
  • Фиксация азимута с индикатором направления
  • Точность компаса
  • Дискретность компаса
ВОЗМОЖНОСТИ ПОДКЛЮЧЕНИЯ
  • Возможности подключения (между устройствами)
    Bluetooth Smart
  • Индивидуальная настройка часов
    USB cable
  • Передача данных
    Wireless / USB cable
  • Уведомления телефона на часах
    with Suunto App
  • Поддержка спортивных онлайн-сообществ
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
  • Совместимость со смартфонами
    iPhone, Android
ПРИЛОЖЕНИЯ SUUNTO APPS
  • Совместимо с устройствами Suunto Apps
  • Макс. кол-во приложений в спортивном режиме
    5
  • Регистрация показателей по приложениям
  • Наиболее рекомендуемые приложения в зависимости от вида спорта
  • Создание собственный показателей при помощи усовершенствованных формул
  • Хронометр, GPS, данные о частоте сердцебиения, погоде и высоте над уровнем моря
  • Данные о беге, езде на велосипеде, плавании
  • Обширный набор математических функций, условные операторы «если... то», звук, подсветка и т. п.
ФУНКЦИИ ДЛЯ АКТИВНОГО ОТДЫХА
GPS ОТСЛЕЖИВАНИЕ И НАВИГАЦИЯ
  • Спутниковые системы
    GPS, GLONASS* *The support for GLONASS, the Russian satellite navigation system, will be available later via a software update.
  • Интервал регистрации GPS
    Best, Good, OK
  • Различные системы координат
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Навигация по путевым точкам и визуальная навигация по маршруту
  • Макс. кол-во интересующих пунктов (POI)
    250
  • Поиск дороги назад
  • Планирование маршрутов с профилем высот
  • Навигация по профилю высоты маршрута в режиме реального времени
  • Пункты маршрута в маршруте / POI в часах
    1000 / 250
  • Анализ маршрута по данным GPS
  • Функция обратного пути
    yes
  • Параметры, просмотр и экспорт маршрутов
  • Планирование маршрута
    in Suunto Movescount.com
АЛЬТИМЕТР
  • Барометрический альтиметр
  • График высот над уровнем моря
  • Высота по данным GPS
  • Объединение данных GPS с данными барометрического альтиметра (FusedAltiTM)
  • Перепад высот над уровнем моря
    yes** ** available as Suunto Apps
  • Общий подъем/спуск
    air pressure based
  • Отображение сведений о совокупном подъеме на часах
  • Вертикальная скорость
    air pressure based
  • Автопереключение профиля высотомера и барометра
  • Интервал регистрации в журнале
    1, 10 s
  • Дискретность
    1 m
  • Диапазон
    -500 - 9999 m
ПОГОДА
  • Термометр
  • Диапазон отображения температуры
  • Дискретность температуры
  • Информация о приливах
ФУНКЦИИ ДЛЯ ТРЕНИРОВКИ
ЧАСТОТА СЕРДЦЕБИЕНИЯ
  • Интервал RR
  • Частота сердцебиения в удаках в минуту
  • Запись сердечного ритма при плавании
  • График частоты сердцебиения в режиме реального времени
  • Калории
    1, 10 s
  • Максимальная эффективность тренировки
  • Время восстановления
  • Руководство во время тренировки на основании скорости и частоты сердцебиения
  • Текущая, средняя и максимальная частота сердцебиения
  • Показатель EPOC в режиме реального времени
  • Частота сердцебиения в % от макс. ЧС
  • Предельные значения частоты сердцебиения
СКОРОСТЬ И РАССТОЯНИЕ
  • Скорость и расстояние по данным GPS
    Integrated
  • Хронограф
  • Поддержка Foot POD
    Bluetooth Smart
  • Поддержка Bike POD
    Bluetooth Smart
  • Расстояние на основе автоматического отсчета этапов
  • Этапы
    > 1000
    1, 10 s
  • Автоматическая пауза
ВОССТАНОВЛЕНИЕ ПОСЛЕ ТРЕНИРОВОК
  • Быстрый тест восстановления (Firstbeat™)
  • Тест восстановления во время сна (Firstbeat™)
  • Время восстановления в зависимости от тренировок
НАГРУЗКА ПРИ ТРЕНИРОВКЕ
  • Сводка из журнала в часах с информацией по этапам
  • Анализ тренировок
    in Suunto App
  • Журнал тренировок с поддержкой текста и изображений
    in Suunto App
ОПЫТ СПОРТИВНЫХ ДОСТИЖЕНИЙ
ПЛАВАНИЕ
  • Темп и расстояние заплыва в бассейне
  • Темп и расстояние заплыва в открытой воде
    Yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
  • Время плавания: длина дорожки, этап, общее
  • Частота гребков, количество и тип
  • Эффективность гребков (SWOLF)
  • Автоматические интервалы
  • Определение стиля плавания с обучением персональному стилю
ЕЗДА НА ВЕЛОСИПЕДЕ
  • Скорость езды
  • Средняя скорость в режиме реального времени
  • Мощность езды на велосипеде (Вт), средняя и максимальная (с датчиком мощности)
    Bluetooth Smart
  • Bike Lap and Lap Maximum Power (с датчиком мощности)
  • Аэродинамическое сопротивление в режиме реального времени (с ANT+ датчиком мощности)
  • Мощность езды на велосипеде за 3 с, 10 с, 30 с (с датчиком мощности)
  • Поддержка Cadence POD
    Bluetooth Smart
  • Подъем в гору в режиме реального времени
    yes, available as Suunto Apps
  • Поддержка нескольких устройств Bike POD
  • Нормализованная мощность (Suunto Apps / TM от Training Peaks)
БЕГ
  • Темп бега
  • Suunto FusedSpeed™
  • Мощность бега
    with Stryd sensor
  • Калибровка Foot POD
    manual or GPS
  • Средний темп в режиме реального времени
  • Сравнение этапов по километрам/милям
  • Оценка времени завершения марафона
  • Средняя длина большого шага
  • Темп бега
    watch or Foot POD
  • Эффективность бега (с технологией Firstbeat™)
ТРЕНИРОВКИ С НЕСКОЛЬКИМИ ВИДАМИ СПОРТА
  • Изменение спортивного режима во время тренировки
  • Настроенные режимы для тренировок с несколькими видами спорта
  • Пост-анализ многоборья по видам спорта
СПОРТИВНЫЕ РЕЖИМЫ
  • Настройка спортивных режимов и дисплеев
    10 modes / 8 displays per mode
Support for Suunto Ambit3 Vertical
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
