Suunto A-10
IN
A robust, easy to use compact compass for general recreational use.
MINIMALISTIC BASEPLATE COMPASS FOR HIKERS AND SCOUTS
Fast, simple and accurate, A-10 baseplate compasses are quick to learn and ideal for navigating with a map and compass. For calculating the distances, A-10 has both metric and empirical scales printed in red to stand out on topographic map.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To overcome this, A-10 has two variants with needles balanced for either the northern or southern hemisphere.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
ХАРАКТЕРИСТИКИ
Размеры56 x 104 x 0 mm / 2.2 x 4.09 x 0 "
Вес30 g / 1.06 oz
Материал безеля:Plastic
КомплектацияSuunto A10 IN, Lanyard and quickrelease, manual
Страна производстваFI
ТЕХНИЧЕСКИЕ ХАРАКТЕРИСТИКИ
ОБЩИЕ
Материал безеляPlastic
Imperial scalesinch, 1:24 000 mi, 1:62 500 mi, cm
Declination correctionfxed scale
Balanced for northern hemisphere✔
Вес30 g / 1.06 oz
Водостойкийinsensitive to water pressure
Тип батареиno battery required
Быстросъемное крепление шнурка✔
Креплениеlanyard
ФИЗИЧЕСКИЕ ХАРАКТЕРИСТИКИ
Рабочая температура-30° C to +60° C / -22° F to +140° F
Температура хранения-30° C to +60° C / -22° F to +140° F
КОМПАС
Шкала направленияdegrees
Стрелкаhigh grade steel
Фиксация курса с индикатором ориентирования✔
Жидкостный, сапфировые опоры осей✔
Точность компаса2.5°
Дискретность компаса2°
