Suunto Vertical 2
Black
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Choose Your Color
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
ESPECIFICACIONES
Medidas48,6 x 48,6 x 13,5 mm / 1,91 x 1,91 x 0,53 ”
Peso87 g
Material del bisel:Acero inoxidable
Material de la lente:Cristal de zafiro
Material de la carcasa:Poliamida reforzada con fibra de vidrio
Material de la correa:Silicona
País de fabricaciónCN
ESPECIFICACIONES TÉCNICAS
Material de la lenteCristal de zafiro
Material de la carcasaPoliamida reforzada con fibra de vidrio
Material de la correaSilicona
Peso87 g
Tallas de muñeca125-175 mm
Ancho de la correa22 mm
Frecuencia cardíaca desde la muñeca integrada✔
Esferas de reloj personalizables✔
Bloqueo de pantalla táctil✔
Pantalla táctil✔
Pantalla en color✔
Alerta mediante vibración✔
Sumergibilidad100 m
Tipo de pilaRecargable de iones de litio
Firmware actualizable✔
Hora, fecha✔
Despertador✔
Hora dual✔
Control de hora automático✔
Temporizador de cuenta atrás✔
Cronómetro✔
IdiomasCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*
Luz de fondoLTPO AMOLED
Luz de fondo configurablebrillo automático
Bloqueo de botonesdurante el ejercicio
Tamaño de pantalla1,5"
Tipo de pantallamatricial
Resolución de pantalla466 × 466
Unidades métricas e imperiales✔
Indicador de bateríaporcentaje/icono
Oxígeno en sangre✔
Pantalla siempre activa✔
ESPECIFICACIONES FÍSICAS
Temperatura de funcionamiento-20° C a +55° C / -5° F a +130° F
Temperatura de almacenamiento-20° C a +55° C / -5° F a +130° F
Temperatura de carga recomendada0 °C a +45 °C / +32 °F a +110 °F
DURACIÓN DE LA BATERÍA
Recordatorios de carga inteligentes✔
Uso diario: modo smartwatchhasta 20 días
Uso diario: solo modo de esperahasta 40 días
Entrenamiento: modo GNSS de todos los sistemas + multibandahasta 65 h (AOD de 60 h)
Entrenamiento: modo GNSS de todos los sistemas + banda únicahasta 75 h (AOD 70 h)
Entrenamiento: promesas de batería para todos los modos65 h/75 h/110 h/250 h
Entrenamiento: modos GNSS de ahorro de energíahasta 250 horas
BRÚJULA
Brújula digital✔
Compensación de inclinación✔
Corrección de la declinación✔
Escala de direccióngrados/milésimas
Agujaindicador de norte
Exactitud de la brújula5°
Resolución de brújula1°
CONECTIVIDAD
Conectividad (entre dispositivos)Bluetooth
Compatible con la Suunto app✔
Notificaciones del teléfono en el reloj✔
Controles multimedia en el reloj✔
Envía desde el reloj respuestas predefinidas a los mensajes entrantesSolo para Android
Compatible con las comunidades deportivas en líneaStrava, TrainingPeaks y más
Actualizaciones del software del reloj desde la nube✔
Actualizaciones de software inalámbricas automáticas✔
Compatibilidad con smartphoneLa mayoría de los modelos comunes son compatibles. Comprueba aquí la lista detallada de compatibilidad
24/7
SEGUIMIENTO DE LA ACTIVIDAD
Contador de pasos✔
CClorías quemadas✔
Objetivos de actividadpasos, calorías
Historial de actividad✔
Calorías quemadas y frecuencia cardíaca durante las actividades diarias✔
Seguimiento de la frecuencia cardíaca diaria mínima✔
SEGUIMIENTO DEL SUEÑO
Duración del sueño✔
Horas de acostarse✔
Tiempo despierto✔
Sueño profundo✔
Frecuencia cardíaca media y mínima durante el sueño✔
Sueño ligero✔
REM✔
VFC durante el sueño✔
Calidad del sueño✔
ESTRÉS Y RECUPERACIÓN
Nivel de recursos diario✔
Estado de estrés y recuperación✔
Medición de la VFC✔
FUNCIONES PARA AIRE LIBRE
Mapas sin conexión en el reloj✔
Sistemas de satéliteGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Sistemas de satélite simultáneos4
Máximos satélites conectados32
Modos de batería inteligenteRendimiento, Resistencia, Ultra, Tour, Personalizado
Frecuencia de grabación GPSMáxima, Buena, OK, Baja
Navegación por puntos de referencia y rutas visuales✔
Niveles de zoom en navegación✔
Auto zoom basado en la forma de la ruta✔
Sendero de navegación en tiempo real✔
Planificación de ruta con perfil de altitud✔
Mapas de terreno y de satélite para aire libre✔
Mapas de calor globales para 20 deportes✔
Planificación de rutas con mapas térmicos✔
Librería de rutas personales sincronizadas con el reloj✔
Ajuste de ruta✔
Navegación de puntos de interés (PDI)✔
Análisis de rutas de GPS✔
Registro, visualización e intercambio de rutas✔
Hora de llegada estimada (ETA)✔
ALTÍMETRO
Altitud barométrica✔
Altitud de GPS✔
Altitud combinada GPS y barométrica (FusedAlti™)✔
Altitud en modo diario✔
Aclimatación a la altitud con oxígeno en sangre✔
Ascenso/descenso total✔
Velocidad vertical✔
Perfil automático alti/baro✔
Frecuencia de grabación de registros1 s
Resolución1 m
Intervalo-500 - 9999 m
METEOROLOGÍA
Hora de amanecer/puesta de sol✔
Alarma de tormenta✔
Presión a nivel del mar✔
Temperatura✔
Intervalo de indicación de temperatura-20° C a +55° C / -5° F a +130° F
Resolución de temperatura1° C/1,5° F
Resolución de presión1 hPa
Gráfica de altitud visible en el resumen de ejercicios✔
FUNCIONES DE ENTRENAMIENTO
ENTRENAMIENTO CON INTERVALOS
Establecer intervalos✔
Guía de intervalos durante el entrenamiento✔
Intervalos estructurados✔
FRECUENCIA CARDÍACA
Medición de frecuencia cardíaca desde la muñeca✔
Compatibilidad con cinturón de frecuencia cardíacaCinturones Bluetooth para FC
Intervalo RRcon Suunto Smart Sensor
Frecuencia cardíaca en latidos por minuto✔
Registra la frecuencia cardíaca al nadar✔
Gráfica de frecuencia cardíaca en tiempo real✔
Frecuencia cardíaca media en tiempo real✔
Calorías✔
Peak Training Effect✔
Zonas personales de frecuencia cardíaca✔
Nivel de forma física (VO2máx)✔
Detección del umbral de lactato✔
Tiempo de recuperación✔
VELOCIDAD Y DISTANCIA
Velocidad y distancia basadas en cadencia✔
Velocidad y distancia de GPS✔
Cronómetro✔
Compatible con Foot PODBluetooth Foot Pods
Autolaps✔
Vueltas manuales✔
Análisis de ritmo, gráficos de velocidad y senderos en el mapa✔
RECUPERACIÓN DE ENTRENAMIENTO
Tras el entrenamiento, el reloj guarda información sobre cómo te has sentido✔
Tiempo de recuperación según entrenamiento✔
CARGA DE ENTRENAMIENTO
Diario con datos de los ejercicios✔
Carga de entrenamiento con totales por deporte✔
Diario de entrenamiento para resúmenes a largo plazo✔
Resumen de ejercicios con datos de vueltas✔
COMPARTE Y REVIVE
Puntuación y comentarios de los ejercicios✔
Sigue a otros miembros y obtén feedback mediante streaming de actividades✔
CAPACIDADES PARA DEPORTE
NATACIÓN
Ritmo y distancia de natación en piscina✔
Distancia de natación en aguas abiertas✔
Tiempo de natación por largo de piscina, vueltas, total✔
Frecuencia de brazada en natación, cuenta y tipo✔
Eficiencia de brazada (SWOLF)✔
Intervalos automáticos✔
Tabla de vueltas de intervalos✔
CICLISMO
Velocidad de ciclismo✔
Velocidad media en tiempo real✔
Bike POD con soporte de velocidad/cadenciaBluetooth Bike Pods
Soporte de medición de Bike PowerMedidores de potencia Bluetooth
Potencia de bicicleta (W), media y máxima (con sensor de potencia)Medidores de potencia Bluetooth
Vuelta de bicicleta y potencia máxima de vuelta (con sensor de potencia)✔
Tabla de vueltas en tiempo real con FC media, potencia media y velocidad media✔
Guía de intervalos con potencia/velocidad/frecuencia cardíaca✔
CARRERA
Ritmo de carrera✔
Suunto FusedSpeed™✔
Ajuste de ruta✔
Potencia de carrera✔
SuuntoPlus™ Ghost runner✔
Calibración de Foot PODautomático
Tabla de vueltas en el reloj y en la app Suunto✔
Cadencia de carrera✔
Guía de intervalos con ritmo/frecuencia cardíaca/distancia en carrera✔
MULTIDISCIPLINARIOS
Cambio de modo de deporte durante el ejercicio✔
Modos multidisciplinarios preconfigurados✔
Análisis posterior de ejercicio multidisciplinario por deportes✔
Resumen de ejercicios multidisciplinarios en el reloj✔
MODOS DE DEPORTE
Modos de deporte y pantallas personalizables✔
Pantallas gráficas en modos de deporte✔
Modos de deporte preinstalados en el reloj> 90
SuuntoPlus™✔
FUNCIONES DE BUCEO
INMERSIÓN EN APNEA
Profundímetro para inmersión con snorkel10 m
