Agotado
Suunto Nautic Bungee Cord & Tank Pod
Money-back guarantee
30-Days Return
Global Support
SKU: SS051302000
Suunto Nautic
Precio de venta€999
Next-generation dive computer for divers who value every moment underwater
Choose your Color
Coming in December
Cantidad
30-Days Return
Global Support
€999
Agotado
Bright AMOLED display, integrated
LED flashlight
Up to 120 hours on a single charge
Wireless tank
pressure
Multi-gas and sidemount support
GPS and underwater route tracking
Suunto App
connectivity
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Rugged leak-proof construction
Glove-friendly
buttons
Designed and tested
in Finland
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Rechargeable battery.
single charge
Reliable power for
multi-day diving trips
Designed for endurance
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Multi-gas and
sidemount support
Customizable dive
views
Full decompression
planning
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Wireless tank
pressure readings
Dual transmitter
support for
sidemount diving
Color-coded visuals
for instant clarity
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Offline maps and GPS help plan and track your routes, while the built-in digital compass provides precise direction underwater. Tide, weather, and sunrise/sunset data support safe surface intervals and the integrated flashlight brings visibility and convenience when light is scarce. Nautic keeps you aware and in control, both underwater and on the surface.
GPS and offline maps
Digital compass for underwater
navigation
LED flashlight, tide, and weather support
for safety
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Automatic dive log
sync
Route and condition tracking
Share and relive
every dive
Explore more with the Suunto app
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Access additional benefits and services from our 200+ partners.
Learn more
ESPECIFICACIONES
  • Medidas
    101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
  • Peso
    227g (with bungee strap) , 232g (with elastic textile strap)
  • Material del bisel:
    Fiber reinforced polymer
  • Material de la lente:
    Panda glass (PANDA-MN228 high alumina silicon glass)
  • Material de la carcasa:
  • Material de la correa:
    Bungee cord / Elastic textile
  • País de fabricación
    FI
ESPECIFICACIONES TÉCNICAS
  • Peso
  • Pantalla en color
  • Alerta mediante vibración
  • Sumergibilidad
    200 m
  • Tipo de pila
    rechargeable lithium-ion
  • Firmware actualizable
  • Hora, fecha
  • Cronómetro
  • Idiomas
  • Luz de fondo
    AMOLED
  • Luz de fondo configurable
    automatic brightness
  • Bloqueo de botones
  • Tamaño de pantalla
    3,26"
  • Tipo de pantalla
    matrix
  • Resolución de pantalla
    720x382
  • Control de hora automático
  • Indicador de batería
    percentage / icon
  • Pantalla siempre activa
ESPECIFICACIONES FÍSICAS
  • Temperatura de funcionamiento en modo de buceo
DURACIÓN DE LA BATERÍA
  • Duración de la batería (inmersión)
    80-190h
BRÚJULA
  • Brújula digital
  • Brújula digital durante el buceo
  • Compensación de inclinación
  • Escala de dirección
  • Aguja
  • Exactitud de la brújula
  • Resolución de brújula
CONECTIVIDAD
    Bluetooth
    Most common models supported, check here for detailed compatibility list
FUNCIONES PARA AIRE LIBRE
  • Mapas sin conexión en el reloj
  • Sistemas de satélite
  • GNSS frequency support
    Dual band (L1+L5)
  • Offline map storage size
    32 GB
    4
    32
  • Frecuencia de grabación GPS
    Best, Good, OK, Low
  • Análisis de rutas de GPS
METEOROLOGÍA
  • Temperatura
  • Resolución de temperatura
    1° C / 1.5° F
FUNCIONES DE ENTRENAMIENTO
FRECUENCIA CARDÍACA
    Bluetooth HR belts
CAPACIDADES PARA DEPORTE
MODOS DE DEPORTE
    Customizable dive
    In dive
    Dive modes
  • Apto para deportes
    Scubadive
FUNCIONES DE BUCEO
BÁSICOS
  • Ajuste de altitud
  • Cálculo de SNC/UTO (FLO)
  • Modos de buceo y pantallas personalizables
  • Modelo de descompresión
    Suunto Bühlmann 16 GF
  • Opciones de perfil de descompresión
    continuous and stepped
  • Historial de inmersiones
    lifetime
  • Tiempo de inmersión
  • Consumo de gas (en tiempo real)
  • Gas máx. pO2
    manual 1.0 - 1.6
  • Cambio de gases
  • Tiempo de gas
  • Gases
    up to 5 gases (Oxygen 21 - 100%)
  • Manómetro
    200m
  • Nítrox (y aire)
  • Tiempo sin vuelo
  • Ajustes personales
    Gradient factors low (10-100) and high (50-100)
  • Parada de seguridad
  • Tiempo en superficie
  • Temporizador
  • Integración de gas inalámbrica
  • Deco planner
  • Helium
  • SNC/UTO (FLO) 80%/100%
  • Tiempo de gas
  • pO2 alto (hiperóxico)
  • pO2 bajo (hipóxico)
  • NDL
  • Presión en la botella
  • Ascenso demasiado rápido
INMERSIÓN EN APNEA
  • Alarma de profundidad
  • Alarma de tiempo de inmersión
Recommended products
Support for Suunto Nautic
