1 / 8
Suunto Vertical 2 Pine Green
1/8
Photos
Video
Money-back guarantee
30-Days Return
Global Support
SKU: SS051207000
Suunto Vertical 2
Pine Green
Precio de venta₡ 283.800
Ultimate adventure watch for outdoor expeditions and training — improved
  • Bright 1.5'' AMOLED display
  • Up to 65 hours battery
  • 115+ sport modes
  • Integrated LED flashlight
  • Improved heart rate tracking
Choose Your Color
Cantidad
30-Days Return
Global Support
₡ 283.800
Añadir a la cesta
Bright 1.5” AMOLED display
115+ sport modes
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Rugged design in titanium or steel
Secure fit silicone straps
Designed and tested in Finland
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 200 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
115+ sport modes
Training Zone with AI Coach
Workout planning
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
Route planning with heatmaps
Climb Guidance planning tool
Dual-band GPS system
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your our ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
300+ partner apps
Growing app ecosystem
Faster hardware, more memory
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Learn more
ESPECIFICACIONES
  • Medidas
    48,6 x 48,6 x 13,5 mm / 1,91 x 1,91 x 0,53 ”
  • Peso
    87 g
  • Material del bisel:
    Acero inoxidable
  • Material de la lente:
    Cristal de zafiro
  • Material de la carcasa:
  • Material de la correa:
    Silicona
  • País de fabricación
    CN
ESPECIFICACIONES TÉCNICAS
    Acero inoxidable
    Cristal de zafiro
    Silicona
  • Peso
    87 g
  • Tallas de muñeca
    125-175 mm
  • Ancho de la correa
    22 mm
  • Bloqueo de pantalla táctil
  • Pantalla táctil
  • Pantalla en color
  • Alerta mediante vibración
  • Sumergibilidad
    100 m
  • Tipo de pila
    Recargable de iones de litio
  • Firmware actualizable
  • Hora, fecha
  • Despertador
  • Hora dual
  • Control de hora automático
  • Cronómetro
  • Idiomas
  • Luz de fondo
    LTPO AMOLED
  • Luz de fondo configurable
    brillo automático
  • Bloqueo de botones
    durante el ejercicio
  • Tamaño de pantalla
    1,5"
  • Tipo de pantalla
    matricial
  • Resolución de pantalla
    466 × 466
  • Indicador de batería
    porcentaje/icono
  • Oxígeno en sangre
  • Pantalla siempre activa
ESPECIFICACIONES FÍSICAS
    0 °C a +45 °C / +32 °F a +110 °F
DURACIÓN DE LA BATERÍA
  • Uso diario: modo smartwatch
    hasta 20 días
  • Uso diario: solo modo de espera
    hasta 40 días
  • Entrenamiento: modo GNSS de todos los sistemas + multibanda
    hasta 65 h (AOD de 60 h)
  • Entrenamiento: modo GNSS de todos los sistemas + banda única
    hasta 75 h (AOD 70 h)
  • Entrenamiento: promesas de batería para todos los modos
    65 h/75 h/110 h/250 h
  • Entrenamiento: modos GNSS de ahorro de energía
    hasta 250 horas
BRÚJULA
  • Brújula digital
  • Compensación de inclinación
  • Escala de dirección
    grados/milésimas
  • Aguja
    indicador de norte
  • Exactitud de la brújula
  • Resolución de brújula
CONECTIVIDAD
    Bluetooth
    Solo para Android
    Strava, TrainingPeaks y más
    La mayoría de los modelos comunes son compatibles. Comprueba aquí la lista detallada de compatibilidad
24/7
SEGUIMIENTO DE LA ACTIVIDAD
  • Contador de pasos
  • CClorías quemadas
  • Objetivos de actividad
    pasos, calorías
  • Historial de actividad
SEGUIMIENTO DEL SUEÑO
  • Duración del sueño
  • Horas de acostarse
  • Tiempo despierto
  • Sueño profundo
  • Frecuencia cardíaca media y mínima durante el sueño
  • Sueño ligero
  • REM
  • VFC durante el sueño
  • Calidad del sueño
ESTRÉS Y RECUPERACIÓN
  • Nivel de recursos diario
  • Medición de la VFC
FUNCIONES PARA AIRE LIBRE
  • Mapas sin conexión en el reloj
  • Sistemas de satélite
  • GNSS frequency support
    Dual band (L1+L5)
    4
    32
    Rendimiento, Resistencia, Ultra, Tour, Personalizado
  • Frecuencia de grabación GPS
    Máxima, Buena, OK, Baja
  • Ajuste de ruta
  • Análisis de rutas de GPS
ALTÍMETRO
  • Altitud barométrica
  • Altitud de GPS
  • Altitud en modo diario
  • Aclimatación a la altitud con oxígeno en sangre
  • Ascenso/descenso total
  • Velocidad vertical
  • Perfil automático alti/baro
    1 s
  • Resolución
    1 m
  • Intervalo
    -500 - 9999 m
METEOROLOGÍA
  • Alarma de tormenta
  • Presión a nivel del mar
  • Temperatura
  • Resolución de temperatura
    1° C/1,5° F
  • Resolución de presión
    1 hPa
FUNCIONES DE ENTRENAMIENTO
ENTRENAMIENTO CON INTERVALOS
  • Establecer intervalos
  • Intervalos estructurados
FRECUENCIA CARDÍACA
    Cinturones Bluetooth para FC
  • Intervalo RR
    con Suunto Smart Sensor
  • Calorías
  • Peak Training Effect
  • Detección del umbral de lactato
  • Tiempo de recuperación
VELOCIDAD Y DISTANCIA
  • Cronómetro
  • Compatible con Foot POD
    Bluetooth Foot Pods
  • Autolaps
  • Vueltas manuales
RECUPERACIÓN DE ENTRENAMIENTO
CARGA DE ENTRENAMIENTO
COMPARTE Y REVIVE
CAPACIDADES PARA DEPORTE
NATACIÓN
  • Intervalos automáticos
CICLISMO
  • Velocidad de ciclismo
    Bluetooth Bike Pods
    Medidores de potencia Bluetooth
CARRERA
  • Ritmo de carrera
  • Suunto FusedSpeed™
  • Ajuste de ruta
  • Potencia de carrera
  • SuuntoPlus™ Ghost runner
  • Calibración de Foot POD
    automático
  • Cadencia de carrera
MULTIDISCIPLINARIOS
MODOS DE DEPORTE
    > 90
  • SuuntoPlus™
FUNCIONES DE BUCEO
INMERSIÓN EN APNEA
  • Profundímetro para inmersión con snorkel
    10 m
Recommended Products
SUPPORT FOR SUUNTO VERTICAL 2
