Suunto Core
Black Yellow
The traditional outdoor watch for off-grid adventures.
SUUNTO CORE - THE OUTDOOR WATCH
Every great adventure starts from within. From a drive to seek out new places and discover new experiences. Your passion is our inspiration. Suunto Core is the essential outdoor watch with a pioneering spirit designed to bring out the explorer in you.
The award-winning Suunto Core gathers a range of data to help you navigate your way through the wilder parts of the world.
Altimeter
The altimeter features a range up to 9000 m (29 500 ft). It is ideally suited for all activities where knowing your altitude and ascent and descent rates is essential. The Core altimeter sports an altitude difference measurement that allows you to track your progress in terms of altitude climbed. The log recorder stores all your movements in altitude between the start and stop times, so you can re-live your trip at home - view graphs of changes in altitude during your treks, find out how much you climbed, the duration of ascents and descents, average ascent and descent speed and more.
Barometer
Suunto Core displays the current sea level pressure as a detailed graph, showing recording of the last 24 hours with a recording interval of 30 minutes. The weather trend indicator is a useful feature providing quick reference to check upcoming weather conditions. The storm alarm notifies you of a sudden drop in air pressure, which may be related to worsening weather conditions.
Automatic Alti/Baro switch
Suunto Core sports an Automatic Alti/Baro switch, a smart feature that senses your movement or lack thereof, switching between altimeter and barometer accordingly. When you’re climbing, it records changes in elevation. And when you stop to rest, it records changes in barometric pressure. A drop in air pressure while you’re sleeping under the stars will be recorded for what it really is: a change in barometric pressure, not altitude
Compass
The digital compass displays the cardinal or half-cardinal point and the North. The declination adjustment function allows you to correct the difference between the true North and magnetic North. You can also set it to track a certain bearing, which helps you follow a chosen direction in the terrain. The compass features a rotating bezel for traditional use (most variants), or a one-touch function that allows you to sight lock and follow a bearing.
Depth meter
Intended for snorkeling, the Suunto Core depth meter provides information on current depth and the maximum depth reached during your snorkeling dive. The maximum depth of the device is 10 m (32,8 ft).
Watch
Watch functions include time, dual time, date, alarm, sports chronograph, countdown timer and predicted times for sunrise and sunset for over 400 locations worldwide.
Suunto Core is available in a range of styles and materials.
PRODUCT HIGHLIGHTS
- Altimeter, barometer, compass
- Weather functions
- Mountain & everywhere use
SPECIFICATIONS
                  Measurements49.1 x 49.1 x 14.5 mm / 1.93 x 1.93 x 0.57 "
                  Weight63 g / 2.22 oz
                  Bezel material:Aluminum
                  Glass material:Mineral crystal
                  Case material:Composite
                  Strap material:Silicone
                  Country of manufactureCN
TECHNICAL SPECIFICATIONS
                      Bezel materialAluminum
                      Glass materialMineral crystal
                      Case materialComposite
                      Strap materialSilicone
                      Water resistance30 m
                      Battery typeCR2032
                      User replaceable battery✔
                      Time, date✔
                      Alarm clock1 daily alarm
                      Dual time✔
                      Countdown timer✔
                      Stopwatch timer✔
                      LanguageEN, DE, ES, FR
                      Backlightelectro-luminescent
                      Configurable backlightactivation: 1 button, all buttons
                      Button lock✔
                      Display typematrix
                      Metric and imperial units✔
                      Battery indicatorlow battery indicator
PHYSICAL SPECIFICATIONS
                      Operating temperature-20° C to +60° C / -5° F to +140° F
                      Storage temperature-30° C to +60° C / -22° F to +140° F
BATTERY LIFE
                      In time mode12 months
COMPASS
                      Digital compass✔
                      Direction scaledegrees
                      Needlenorth indicator
                      Bearing lock with orienting indicator✔
                      Compass accuracy5°
                      Compass resolution1°
OUTDOOR FUNCTIONS
ALTIMETER
                      Barometric altitude✔
                      Altitude graph✔
                      Altitude difference✔
                      Total ascent/descentair pressure based
                      Automatic alti/baro profile✔
                      Log recording rate1, 5, 10, 30, 60 s
                      Resolution1 m
                      Range-500 - 9000 m
WEATHER
                      Sunrise/sunset times✔
                      Storm alarm✔
                      Sea level pressure✔
                      Temperature✔
                      Temperature display range✔
                      Temperature resolution1°
                      Pressure resolution1 hPa / 0.03 inHg
                      Max weather recording length7 days
                      Sea level pressure graph✔
                      Weather trend indicator✔
DIVING FUNCTIONS
FREEDIVING
                Depth meter for snorkeling10 m
