Suunto A-10
IN
A robust, easy to use compact compass for general recreational use.
MINIMALISTIC BASEPLATE COMPASS FOR HIKERS AND SCOUTS
Fast, simple and accurate, A-10 baseplate compasses are quick to learn and ideal for navigating with a map and compass. For calculating the distances, A-10 has both metric and empirical scales printed in red to stand out on topographic map.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To overcome this, A-10 has two variants with needles balanced for either the northern or southern hemisphere.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
SPECIFICATIONS
Measurements56 x 104 x 0 mm / 2.2 x 4.09 x 0 "
Weight30 g / 1.06 oz
Bezel material:Plastic
What's in the box?Suunto A10 IN, Lanyard and quickrelease, manual
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialPlastic
Imperial scalesinch, 1:24 000 mi, 1:62 500 mi, cm
Declination correctionfxed scale
Balanced for northern hemisphere✔
Water resistanceinsensitive to water pressure
Battery typeno battery required
Lanyard quick release✔
Attachmentlanyard
PHYSICAL SPECIFICATIONS
Operating temperature-30° C to +60° C / -22° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
COMPASS
Direction scaledegrees
Needlehigh grade steel
Bearing lock with orienting indicator✔
Liquid filled and jewel bearing✔
Compass accuracy2.5°
Compass resolution2°
