Suunto Vector Charcoal Gray
SKU: SS020178000
Legendary outdoor sports watch with a solid track record of high-altitude performance
12.100 kr
Out of Stock
THE ORIGINAL MOUNTAIN WATCH WITH HR
After a decade of travels, adventures and courageous expeditions, the Suunto Vector is still the most legendary watch with altimeter, barometer and compass. With technology and durability that can take on the harshest of environments, the Suunto Vector is the choice of professionals.
PRODUCT HIGHLIGHTS
  • Altimeter, barometer, compass, HR
  • Robust and light
  • Trusted by professionals
SPECIFICATIONS
  • Measurements
    51.4 x 45.6 x 15.3 mm / 2.02 x 1.8 x 0.6 "
  • Weight
    54 g / 1.9 oz
  • Bezel material:
    Composite
  • Glass material:
    Acrylic
  • Case material:
    Composite
  • Strap material:
    Elastomer
  • What's in the box?
    Suunto Vector Charcoal Gray, Quick guide
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Composite
  • Glass material
    Acrylic
  • Case material
    Composite
  • Strap material
    Elastomer
  • Declination correction
    yes
  • Weight
    54 g / 1.9 oz
  • Water resistance
    30 m
  • Battery type
    CR2430
  • User replaceable battery
  • Time, date
  • Alarm clock
    up to 3 daily alarms
  • Countdown timer
  • Stopwatch timer
  • Language
    EN
  • Backlight
    electro-luminescent
  • Display type
    7 segments
  • Metric and imperial units
  • Battery indicator
    low battery indicator
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • In time mode
    12 months
COMPASS
  • Digital compass
  • Tilt compensation
    bubble level
  • Direction scale
    degrees
  • Needle
    north-south indicator
  • Compass accuracy
  • Compass resolution
OUTDOOR FUNCTIONS
ALTIMETER
  • Barometric altitude
  • Altitude difference
  • Total ascent/descent
    air pressure based
  • Log recording rate
    20 s / 1, 10, 60 min
  • Resolution
    5 m
  • Range
    -500 - 9000 m
WEATHER
  • Sea level pressure
  • Temperature
  • Temperature display range
  • Temperature resolution
  • Pressure resolution
    1hPa/0.05 inHg
  • Max weather recording length
    4 days
  • Weather trend indicator
TRAINING FUNCTIONS
SPEED AND DISTANCE
  • Laps
    2
Support for Suunto Vector
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
