Suunto Flow Restrictor Tank POD Kit
Free shipping on all orders over 130 £
Satisfied or your money back
SKU: SS023614000
Sale price269 kr
The Suunto Flow Restrictor for Suunto Tank POD
Quantity
visa paypal master apple_pay american_express diners_club klarna vipps
269 kr
Add to cart
The Suunto Flow Restrictor is used with the Suunto Tank POD. You should remove the restrictor only for cleaning or changing scuba gear. The restrictor must be re-installed before using the transmitter again.
The Suunto Flow Restrictor Tank POD Kit contains one Type A and one Type B flow restrictor. The shorter Flow Restrictor Type A is used when the Suunto Tank POD is installed directly to a first-stage regulator high pressure port.
The longer Flow Restrictor Type B is used when the Suunto Tank POD is connected to a high pressure hose extension, with the hose attached to the first stage regulator high pressure port.
The Suunto Flow Restrictor Tank POD Kit also contains a Suunto Tank POD Quick Guide with installation instructions.
