1 / 9
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
SUUNTO MC-2
NH Mirror Compass
1/9
Money-back guarantee
30-Days Return
Global Support
SKU: SS004231001
SUUNTO MC-2 NH Mirror Compass
Sale price€75
A professional mirror compass for orienteering, hiking and slope measurements for mountain adventures.
  • Balanced for northern hemisphere metric, UTM scales and inch ruler
  • Adjustable declination correction
  • Mirror for sighting bearings and signaling, with magnifying lens
  • Compass with inclinometer
  • Luminescent markings for working in low light
  • Detachable snap-lock lanyard with wristlock
    Choose Your Color
    Quantity
    30-Days Return
    Global Support
    €75
    Add to cart
    Made in Finland
    Limited lifetime warranty
    Exceptionally stable & fast needle
    Baseplate with magnifying lens
    Luminescent markings for low light
    Sighting compass for mountain adventures
    When venturing out into new territory, MC-2 sighting compasses offer precision navigation with a variety of carefully engineered and dependable features for challenging conditions. Depending on the variant, MC-2 comes with Metric UTM scales and inch ruler or USGS UTM scales.
    The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
    One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
    Correct the declination between map north (North Pole) and magnetic north for trusted navigation. Read more about declination correction.
    Stable operation
    The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
    Mirror for more
    The mirror on a compass serves the dual purpose of allowing you to sight bearings accurately and facilitating signaling by reflecting sunlight.
    Accurate bearings
    Sighting hole and notch in a compass facilitate precise navigation by allowing you to align the compass with distant landmarks and obtain accurate bearings.
    Integrated clinometer
    The clinometer is useful in uneven terrain where you need to determine slope gradient to pinpoint your exact location. It also helps to measure altitude.
    The lanyard with wristlock is easy to detach for working with the map.
    Made in Finland
    All Suunto compasses are handcrafted at our factory with 100% renewable energy.
    Sustainable design from Finland
    Carbon footprint 1.3 kg CO2e
    According to a category-level Life Cycle Assessment (LCA) of Suunto field compasses*, one compass in this category creates on average 1.3 kg CO₂e emissions during its whole lifespan. 1.3 kg CO₂e equals to, for example, driving a fossil fuel car for 8 kilometers.
    We have fully offset the lifespan emissions of all compasses in this category with Verified Carbon Units.
    *Including A-10, A-30, M-3, M-3 Global, AIM-6, AIM-30, MCB, MC-2, MC-2 Global, MB-6 and MB-6G compasses
    Data source: Gov.uk, Dept for Business, Energy and Industrial Strategy, 2025
    Made with 100% renewable energy
    Suunto factory, where Suunto compasses are made, is located in Vantaa, Finland. Here we use 100% renewable, carbon neutral energy in all our operations. This is a key factor in enabling the Suunto compass to achieve a small carbon footprint of 1.3 kg CO₂e* over its full lifespan.
    *Based on average category-level emissions for selected Suunto field compasses, including A-10, A-30, M-3, M-3 Global, AIM-6, AIM-30, MCB, MC-2, MC-2 Global, MB-6, and MB-6G.
    100% carbon offset
    We offset the lifetime CO₂e emissions of each sold Suunto compass* with Verified Carbon Units via Tree-Nation. The offset is done in a reforestation project in Southeast Africa that plants trees, protects biodiversity, and supports local communities in creating sustainable livelihoods.
    *This applies to Suunto field compasses including A-10, A-30, M-3, M-3 Global, AIM-6, AIM-30, MCB, MC-2, MC-2 Global, MB-6, and MB-6G.
    SPECIFICATIONS
    • Measurements
      65 x 101 x 18 mm / 2.56 x 3.98 x 0.71 "
    • Weight
      74 g / 2.61 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto MC-2 NH Mirror Compass, lanyard with wristlock and declination correction tool, Quickrelease, Quick Guide
    • Country of manufacture
      FI
    TECHNICAL SPECIFICATIONS
    • Bezel material
      Plastic
    • Metric scales
      cm, 1:25 000 km UTM, 1:50 000 km UTM
    • Imperial scales
      inch
    • Declination correction
      adjustable
    • Weight
      74 g / 2.61 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      bezel, orienting markings, direction of travel
    • Lanyard quick release
    • Attachment
      lanyard
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    COMPASS
    • Direction scale
      degrees
    • Needle
      high grade steel
    • Liquid filled and jewel bearing
    • Compass accuracy
      2.5°
    • Compass resolution
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Magnifying lens
    • Mirror
    • Sighting
      mirror, notch and hole
    CLINOMETER
    • Clinometer
    • Liquid filled
    • Clinometer scales
      0 ± 90°
    • Inclination accuracy
    • Inclination resolution
