Suunto D5
Copper
An easy-to-use dive computer with interchangeable straps that fit your style. Made in Finland.
Choose your Color
Quantity
€399,20
Diving life made easy
Suunto D5 is designed to be so clear and easy-to-use that you can just enjoy and focus on exploring the wonderful underwater world. When not diving, connect wirelessly to Suunto app and receive notifications from the applications you use. Play with style by choosing your favorite color or just by simply changing the straps to match your looks. Suunto D5 connects your two lives: the adventure under the surface but also the great experiences you can relive and share with your friends afterwards.
BENEFITS
EASY TO USE
DIVING LIFE MADE EASY
MATCH WITH YOUR STYLE
WIRELESS CONNECTIVITY
SPECIFICATIONS
Measurements53 x 53 x 16.3 mm / 2.09 x 2.09 x 0.64 "
Weight90 g / 3.17 oz
Bezel material:Stainless steel
Glass material:Mineral crystal
Case material:Reinforced composite
Strap material:Silicone
What's in the box?Suunto D5 Copper, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet, Suunto sticker
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialStainless steel
Glass materialMineral crystal
Case materialReinforced composite
Strap materialSilicone
Vibration alert✔
Water resistance100 m (ISO 6425, EN 13319)
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock1 daily alarm
Dual time✔
Stopwatch timer✔
LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TW, ZH
BacklightLED
Configurable backlight✔
Display typeMemory in pixel
Display resolution320 x 300
Metric and imperial units✔
Battery indicatoricon + dive hours remaining
PHYSICAL SPECIFICATIONS
Operating temperature0° C to +40° C / +32° F to +104° F
Storage temperature-20 ° C to +50 ° C / -4° F to +122° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Battery life (dive)up to 6-12 h of diving fully charged or up to 6 days in time mode
COMPASS
Digital compass✔
Tilt compensationup to 45°
Declination correction✔
Direction scaledegrees
Needlecompass rose
Bearing lock with direction indicator✔
Globally balanced✔
Compass accuracy+/- 15°
Compass resolution1°
CONNECTIVITY
Connectivity (between devices)inductive (Tank POD), Bluetooth Smart
Compatible with Suunto app✔
Watch customizationCustomizable with DM5
Phone notifications on the watch✔
Compatible with DM5✔
Log transferBluetooth Smart / USB cable
Smartphone compatibilityMost common models supported
OUTDOOR FUNCTIONS
WEATHER
Temperature✔
Temperature display range-20 to +50 °C/-4 to +122 °F
Temperature resolution1° C / 1.5° F
DIVING FUNCTIONS
BASIC
Altitude adjustment0 - 300 m / 300 -1500 m / 1500 - 3000 m
Ascent time display0 - 999 min ( > after 999)
CNS/OTU (OLF) calculation✔
Customizable dive modes and displays✔
Decompression modelSuunto Fused™ RGBM 2
Deep Stop✔
Dive historylifetime
Dive time0 to 999 min
Freedive✔
Gas consumption (real-time)✔
Gas max pO21.6
Gas time✔
Gasesup to 3 gases (Oxygen 21 - 99%)
Gauge✔
Logbook bookmarks✔
Logbook memory200h or 400 dives which comes first
Logbook sampling ratesscubadive 10s, freedive 1s
Maximum operating depth (EN 13319)100 m / 328 ft (EN 13319, ISO 6425)
Nitrox (and air)✔
No fly time✔
No-decompression planner✔
Personal adjustmentP+2, P+1, P0, P-1, P-2
Safety Stop✔
Surface time0 to 100 h
Timer✔
Visual styleGraphical
Wireless air integrationoptional (up to 3 different tanks with Suunto Tank POD)
DIVE ALARMS AND NOTIFICATIONS
CNS/OTU (OLF) 80% / 100%✔
Decompression ceiling violation✔
Deepstop violation✔
Dive time✔
Gas time✔
High pO2 (hyperoxic)✔
Maximum depth✔
Switch gas (better gas is available)✔
Tank pressure✔
Too fast ascent✔
FREEDIVING
Depth alarm✔
Depth notifyyes (5)
Dive time alarm✔
Freedive day history✔
Freedive number✔
Freedive total historylifetime
Surface time notify✔
