Suunto Ambit3 Peak Sapphire Blue (HR)
The GPS watch for multisport athletes and explorers with heart rate monitoring
$150,700
CLASSIC ADVENTURE COMPANION
Whether you’re reaching for the top of the summit or a new personal best, Suunto Ambit3 Peak will be there to help you. A GPS watch designed for adventures that reach the edges of the map, it provides everything you need to find your way, stay safe and follow your progress.
KEY FEATURES
LONG BATTERY LIFE
GPS NAVIGATION
BAROMETER FOR ALTITUDE ACCURACY
WEATHER FUNCTIONS
100 M WATER RESISTANT
10 SPORT MODES
DIGITAL COMPASS
UPDATABLE SOFTWARE
BENEFITS
Right tools for the outdoors
Adventure-proof
Sports tracking essentials
SPECIFICATIONS
Measurements50 x 50 x 17 mm / 1.97 x 1.97 x 0.67 "
Weight92 g / 3.25 oz
Bezel material:Steel
Glass material:Sapphire crystal
Case material:Polyamide
Strap material:Silicone
What's in the box?Suunto Ambit3 Peak Sapphire Blue, Suunto Smart Sensor and blue heart rate belt (size M), USB cable, quick guide, warranty leaflet
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialSteel
Glass materialSapphire crystal
Case materialPolyamide
Strap materialSilicone
Water resistance100 m
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock1 daily alarm
Dual time✔
Automatic timekeeping✔
Countdown timer✔
Stopwatch timer✔
LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
BacklightLED
Configurable backlightbrightness / mode
Button lockcustomizable
Invert display✔
Display typematrix
Display resolution128 x 128
Metric and imperial units✔
Battery indicatorpercentage / icon
Autoscrolling of exercise displays✔
Memory left indicator✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
In time mode30 days
Training mode with GPS20, 30, 200 h For more information www.suunto.com/software-updates
COMPASS
Digital compass✔
Tilt compensationfull
Declination correction✔
Direction scaledegrees / mils
Needlenorth indicator
Bearing lock with direction indicator✔
Compass accuracy5°
Compass resolution1°
CONNECTIVITY
Connectivity (between devices)Bluetooth Smart
Watch customizationUSB cable
Data transferWireless / USB cable
Phone notifications on the watchwith Suunto App
Compatible with online sports communitiesStrava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
Smartphone compatibilityiPhone, Android
SUUNTO APPS
Compatible with Suunto Apps✔
Max. nr. of apps per sport mode5
Logging of app specific metrics✔
Most recommended apps by activity✔
Create own metrics with advanced formulas✔
Chrono, GPS, HR, weather and altitude data✔
Running, cycling, swimming data✔
Rich math functions, if/then-logic, sound, backlight, etc.✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS
GPS recording rate1, 5, 60 s
Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
Waypoint and visual route navigation✔
Max. nr. of Points of Interest (POIs)250
Find back✔
Route planning with altitude profile✔
Route altitude profile navigation in real-time✔
Route points per route / POIs in watch1000 / 250
GPS track analysis✔
Track backyes
Track logging, viewing and sharingin Suunto App
Route planningin Suunto Movescount.com
ALTIMETER
Barometric altitude✔
Altitude graph✔
GPS altitude✔
Combined GPS and barometric altitude (FusedAlti™)✔
Altitude differenceyes** ** available as Suunto Apps
Total ascent/descentair pressure based
Vertical speedair pressure based
Automatic alti/baro profile✔
Log recording rate1, 10 s
Resolution1 m
Range-500 - 9999 m
WEATHER
Sunrise/sunset times✔
Storm alarm✔
Sea level pressure✔
Temperature✔
Temperature display range✔
Temperature resolution1°
Pressure resolution1 hPa / 0.03 inHg
Max weather recording lengthpast 26 hours
Sea level pressure graph✔
Tide informationyes** ** available as Suunto Apps
Weather trend indicator✔
TRAINING FUNCTIONS
HEART RATE
RR interval✔
Heart rate in beats per minute✔
Records heart rate in swimmingyes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Heart rate graph in real time✔
Calories✔
Peak Training Effect✔
Recovery time✔
Speed and heart rate-based guidance during exercise✔
Real-time average and max heart rate✔
Real time EPOCyes** ** available as Suunto Apps
Heart rate in % of max hr✔
Heart rate limits✔
SPEED AND DISTANCE
GPS speed and distanceIntegrated
Chrono✔
Foot POD supportBluetooth Smart
Bike POD supportBluetooth Smart
Distance based autolaps✔
Laps> 1000
Autopause✔
TRAINING RECOVERY
Quick recovery test (Firstbeat™)✔
Sleep recovery test (Firstbeat™)✔
Training based recovery time✔
TRAINING LOAD
Log summary on the watch with lap details✔
Training analysisin Suunto App
Training logbook with story and image supportin Suunto App
SPORT EXPERTISE
SWIMMING
Pool swim pace and distance✔
Openwater swim pace and distance✔
Records heart rate in swimmingYes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Swimming time by pool length, lap, total✔
Swimming stroke rate, count and type✔
Stroke efficiency (SWOLF)✔
Automatic intervals✔
Swim styles detection with personal style teaching✔
CYCLING
Cycling speed✔
Average speed in real time✔
Bike Power (W), average and maximum (with power sensor)Bluetooth Smart
Bike Lap and Lap Maximum Power (with power sensor)✔
Aerodynamic drag in real time (with power sensor)yes** ** available as Suunto Apps
Bike Power 3s, 10s, 30s (with power sensor)✔
Cadence POD SupportBluetooth Smart
Hill incline in real timeyes, available as Suunto Apps
Multiple Bike POD support✔
Normalized Power (Suunto Apps / TM by Training Peaks)yes** ** available as Suunto Apps
RUNNING
Running pace✔
Suunto FusedSpeed™✔
Running powerwith Stryd sensor
Foot POD calibrationmanual or GPS
Average pace in real time✔
Lap comparisons by kilometer/mile✔
Marathon End-time Estimatoryes** ** available as Suunto Apps
Average stride lengthyes** ** available as Suunto Apps
Running cadencewatch or Foot POD
Running Performance (Firstbeat™)✔
MULTISPORTS
Change sport mode during exercise✔
Preconfigured multisport modes✔
Post-analysis of multisport exercise by sport✔
SPORT MODES
Customizable sport modes and displays10 modes / 8 displays per mode
