Refurbished Suunto Core Alpha
Stealth
The traditional outdoor watch for off-grid adventures with military-grade durability.
Choose Your Color
SUUNTO CORE ALPHA
Suunto Core Alpha packs the key outdoor features in robust construction with a comfortable yet durable textile strap. Combining an altimeter, barometer and compass with weather information, it will bring out the explorer in you. The night vision goggle friendly red backlight helps you stay unnoticed when hunting.
Suunto Core Alpha is designed and made in Finland with the quality that Suunto is known for. Tested to military standards (MIL-STD-810), the watch will make sure your journey is safe and successful even in the toughest and most demanding conditions. Suunto Core Alpha has passed 9 tests, including pressure, heat/cold, shock, drop, freeze/thaw, rain, humidity and dust.
Key features
Barometer
Compass
Altimeter
Red backlight
Weather functions
Sunrise and sunset times
30 m water resistant
Benefits
- Altimeter
- Barometer
- Compass, adjustable declination
- Temperature
- Storm alarm
- Sunset/sunrise times
- Tested to military standards
- Made in Finland
- Red backlight, night vision goggle friendly
- Textile strap (Berry amendment compliant)
- User replaceable battery (CR2032), battery life ~12 months
- Multiple watch, date and time functions
- 30 m / 100 ft water resistance
- Depth meter for snorkeling (10 meters)
- Metric and imperial units
- Multilingual menu: EN, DE, ES, FR
SPECIFICATIONS
Measurements49.5 x 49.5 x 15.1 mm / 1.95 x 1.95 x 0.59 "
Weight67 g / 2.36 oz
Bezel material:Aluminum
Glass material:Mineral crystal
Case material:Composite
Strap material:Textile
What's in the box?Suunto Core Alpha Stealth and Quick Guide
Country of manufactureCN
TECHNICAL SPECIFICATIONS
Bezel materialAluminum
Glass materialMineral crystal
Case materialComposite
Strap materialTextile
Wrist sizes140-240 mm
Water resistance30 m
Battery typeCR2032
User replaceable battery✔
Time, date✔
Alarm clock1 daily alarm
Dual time✔
Countdown timer✔
Stopwatch timer✔
LanguageEN, DE, ES, FR
BacklightLED
Configurable backlightactivation: 1 button, all buttons
Button lock✔
Display typematrix
Metric and imperial units✔
Battery indicatorlow battery indicator
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
BATTERY LIFE
In time mode12 months
COMPASS
Digital compass✔
Direction scaledegrees
Needlenorth indicator
Bearing lock with orienting indicator✔
Compass accuracy5°
Compass resolution1°
OUTDOOR FUNCTIONS
ALTIMETER
Barometric altitude✔
Altitude graph✔
Altitude difference✔
Total ascent/descentair pressure based
Automatic alti/baro profile✔
Log recording rate1, 5, 10, 30, 60 s
Resolution1 m
Range-500 - 9000 m
WEATHER
Sunrise/sunset times✔
Storm alarm✔
Sea level pressure✔
Temperature✔
Temperature display range✔
Temperature resolution1°
Pressure resolution1 hPa / 0.03 inHg
Max weather recording length7 days
Sea level pressure graph✔
Weather trend indicator✔
SPORT EXPERTISE
HUNTING
Red backlight, compatible with night vision goggles✔
DIVING FUNCTIONS
FREEDIVING
Depth meter for snorkeling10 m
