Suunto D5
Aqua Blue
An easy-to-use dive computer with interchangeable straps that fit your style. Made in Finland.
Choose your Color
            Quantity
        £364
        Diving life made easy
Suunto D5 is designed to be so clear and easy-to-use that you can just enjoy and focus on exploring the wonderful underwater world. When not diving, connect wirelessly to Suunto app and receive notifications from the applications you use. Play with style by choosing your favorite color or just by simply changing the straps to match your looks. Suunto D5 connects your two lives: the adventure under the surface but also the great experiences you can relive and share with your friends afterwards.
BENEFITS
              EASY TO USE
              DIVING LIFE MADE EASY
              MATCH WITH YOUR STYLE
              WIRELESS CONNECTIVITY
            SPECIFICATIONS
                  Measurements53 x 53 x 16.3 mm / 2.09 x 2.09 x 0.64 "
                  Weight90 g / 3.17 oz
                  Bezel material:Stainless steel
                  Glass material:Mineral crystal
                  Case material:Reinforced composite
                  Strap material:Silicone
                  What's in the box?Suunto D5 Aqua Blue, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet, Suunto sticker
                  Country of manufactureFI
TECHNICAL SPECIFICATIONS
                      Bezel materialStainless steel
                      Glass materialMineral crystal
                      Case materialReinforced composite
                      Strap materialSilicone
                      Vibration alert✔
                      Water resistance100 m (ISO 6425, EN 13319)
                      Battery typerechargeable lithium-ion
                      Firmware upgradable✔
                      Time, date✔
                      Alarm clock1 daily alarm
                      Dual time✔
                      Stopwatch timer✔
                      LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TW, ZH
                      BacklightLED
                      Configurable backlight✔
                      Display typeMemory in pixel
                      Display resolution320 x 300
                      Metric and imperial units✔
                      Battery indicatoricon + dive hours remaining
PHYSICAL SPECIFICATIONS
                      Operating temperature0° C to +40° C / +32° F to +104° F
                      Storage temperature-20 ° C to +50 ° C / -4° F to +122° F
                      Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
                      Battery life (dive)up to 6-12 h of diving fully charged or up to 6 days in time mode
COMPASS
                      Digital compass✔
                      Tilt compensationup to 45°
                      Declination correction✔
                      Direction scaledegrees
                      Needlecompass rose
                      Bearing lock with direction indicator✔
                      Globally balanced✔
                      Compass accuracy+/- 15°
                      Compass resolution1°
CONNECTIVITY
                      Connectivity (between devices)inductive (Tank POD), Bluetooth Smart
                      Compatible with Suunto app✔
                      Watch customizationCustomizable with DM5
                      Phone notifications on the watch✔
                      Compatible with DM5✔
                      Log transferBluetooth Smart / USB cable
                      Smartphone compatibilityMost common models supported
OUTDOOR FUNCTIONS
WEATHER
                      Temperature✔
                      Temperature display range-20 to +50 °C/-4 to +122 °F
                      Temperature resolution1° C / 1.5° F
DIVING FUNCTIONS
BASIC
                Altitude adjustment0 - 300 m / 300 -1500 m / 1500 - 3000 m
                Ascent time display0 - 999 min ( > after 999)
                CNS/OTU (OLF) calculation✔
                Customizable dive modes and displays✔
                Decompression modelSuunto Fused™ RGBM 2
                Deep Stop✔
                Dive historylifetime
                Dive time0 to 999 min
                Freedive✔
                Gas consumption (real-time)✔
                Gas max pO21.6
                Gas time✔
                Gasesup to 3 gases (Oxygen 21 - 99%)
                Gauge✔
                Logbook bookmarks✔
                Logbook memory200h or 400 dives which comes first
                Logbook sampling ratesscubadive 10s, freedive 1s
                Maximum operating depth (EN 13319)100 m / 328 ft (EN 13319, ISO 6425)
                Nitrox (and air)✔
                No fly time✔
                No-decompression planner✔
                Personal adjustmentP+2, P+1, P0, P-1, P-2
                Safety Stop✔
                Surface time0 to 100 h
                Timer✔
                Visual styleGraphical
                Wireless air integrationoptional (up to 3 different tanks with Suunto Tank POD)
DIVE ALARMS AND NOTIFICATIONS
                CNS/OTU (OLF) 80% / 100%✔
                Decompression ceiling violation✔
                Deepstop violation✔
                Dive time✔
                Gas time✔
                High pO2 (hyperoxic)✔
                Maximum depth✔
                Switch gas (better gas is available)✔
                Tank pressure✔
                Too fast ascent✔
FREEDIVING
                Depth alarm✔
                Depth notifyyes (5)
                Dive time alarm✔
                Freedive day history✔
                Freedive number✔
                Freedive total historylifetime
                Surface time notify✔
