1 / 2
Suunto ANT Heart Rate Belt
1/2
Money-back guarantee
30-Days Return
Global Support
SKU: SS013588000
Sends accurate heart rate information to your compatible Suunto device
30-Days Return
Global Support
405.000 Ft
Out of Stock
Suunto ANT Heart Rate Belt - Monitor with accuracy
Monitor your heart rate with precision - Suunto ANT Heart Rate Belt sends accurate heart rate information to your compatible Suunto watch.
Accuracy and comfort are a must for monitoring your heart rate. Easy to use and comfortable to wear, the ANT Heart Rate Belt sends precise heart rate information to your compatible Suunto product through disturbance-free ANT technology - giving you an exact, real-time reading of your performance while you train.
Made from soft textile materials, the ANT Heart Rate Belt comes equipped with unique traction strips to keep it in place, eliminating the need to over-tighten. The thin length-adjustment buckles minimize the risk of friction and abrasions, allowing you to train with minimal interruption. The heart rate belt features a closing buckle conveniently located in the front, which also doubles as an easy-to-reach key for the battery cover.
Suunto ANT Heart Rate Belt is compatible with Suunto AmbitAmbit2, Ambit2 S, Ambit2 R as well as with Suunto M4, M5Quest, t3, t4, and t6 heart rate monitors.  The belt is not compatible with Ambit3 watches – please check out Suunto Smart Sensor instead.
Videos
How to change the strap of your Suunto Core Classic outdoor watch
See how to change a new battery to Lumi and Core.
Learn how to adjust the display contrast of your Core.
Learn how to set time and alarm of your Suunto Core.
How to calibrate the compass
Watch the video "First Settings" to get your Core ready for use.
Learn how the altimeter of your Suunto watch works and how to ensure a most precise measurement.
