1 / 11
Suunto Traverse Slate
1/11
Money-back guarantee
30-Days Return
Global Support
SKU: SS022293000
GPS outdoor watch with versatile navigation functions for hiking and trekking
30-Days Return
Global Support
£710
Out of Stock
Go explore
Curiosity drives us to seek out and discover new places, but it’s the confidence of finding our way that encourages us to step off the beaten track. Topographic maps in Suunto Movescount and the integrated GPS and GLONASS navigation of Suunto Traverse help you plan your hikes and find your way in the wild. The automatic breadcrumb of your track ensures you can re-trace your steps when needed. The strong build and powerful battery of Suunto Traverse keep you exploring hour after hour. The matte finish of the composite case and a custom dyed premium textile strap make Suunto Traverse Slate an ideal companion both for treks in the wild, as well as for everyday use. Sold exclusively in the Suunto webshop.
PRODUCT HIGHLIGHTS
  • Find your way with integrated GPS navigation
  • Up to 100 hours battery life, sunset/sunrise times and storm alarm
  • Made in Finland
Gear of the Year 2016
SPECIFICATIONS
  • Measurements
    50 x 50 x 16.5 mm / 1.97 x 1.97 x 0.65 "
  • Weight
    80 g / 2.82 oz
  • Bezel material:
    Stainless steel
  • Glass material:
    Mineral crystal
  • Case material:
    Composite
  • Strap material:
    Textile
  • What's in the box?
    Suunto Traverse Slate, USB cable, quick guide, warranty leaflet
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Stainless steel
  • Glass material
    Mineral crystal
  • Case material
    Composite
  • Strap material
    Textile
  • Weight
    80 g / 2.82 oz
  • Flashlight backlight option
  • Vibration alert
  • Water resistance
    100 m
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Automatic timekeeping
  • Countdown timer
  • Stopwatch timer
  • Language
  • Backlight
    LED
  • Configurable backlight
    brightness / mode
  • Button lock
    customizable
  • Invert display
  • Display type
    matrix
  • Display resolution
    128 x 128
  • Metric and imperial units
  • Battery indicator
    percentage / icon
  • Memory left indicator
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • In time mode
    14 days
  • Training mode with GPS
    10, 15, 100 h For more information www.suunto.com/software-updates
COMPASS
  • Digital compass
  • Tilt compensation
    full
  • Declination correction
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
  • Compass resolution
CONNECTIVITY
    Bluetooth Smart
  • Watch customization
    USB cable
  • Data transfer
    Wireless / USB cable
    with Suunto App
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
  • Smartphone compatibility
    Most common models supported
SUUNTO APPS
  • Compatible with Suunto Apps
  • Max. nr. of apps per sport mode
    4
  • Logging of app specific metrics
  • Most recommended apps by activity
  • Create own metrics with advanced formulas
  • Chrono, GPS, HR, weather and altitude data
  • Rich math functions, if/then-logic, sound, backlight, etc.
24/7
ACTIVITY TRACKING
  • Step counter
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    GPS, GLONASS
  • GPS recording rate
    Best, Good, OK
  • Coordinate systems
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Max. nr. of Points of Interest (POIs)
    250
  • Find back
    in Suunto Movescount.com
  • Route altitude profile navigation in real-time
  • Route points per route / POIs in watch
    1000 / 250
  • GPS track analysis
    in Suunto App
  • Track back
    yes, incorporated with breadcrumb trail
    in Suunto App
  • Route planning
ALTIMETER
  • Barometric altitude
  • Altitude graph
  • GPS altitude
  • Altitude difference
    in log summary, and real time as an App
  • Total ascent/descent
    air pressure based
  • Vertical speed
    air pressure based
  • Automatic alti/baro profile
  • Log recording rate
    1, 10 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
WEATHER
  • Sunrise/sunset times
  • Storm alarm
  • Sea level pressure
  • Temperature
  • Temperature display range
  • Temperature resolution
  • Pressure resolution
    1 hPa / 0.03 inHg
  • Max weather recording length
    past 26 hours
  • Sea level pressure graph
  • Tide information
    yes** ** available as Suunto Apps
  • Weather trend indicator
TRAINING FUNCTIONS
HEART RATE
  • Calories
    1, 10 s
  • Heart rate in % of max hr
SPEED AND DISTANCE
  • GPS speed and distance
    Integrated
  • Chrono
  • Distance based autolaps
  • Laps
    > 1000
    1, 10 s
  • Autopause
TRAINING LOAD
  • Log summary on the watch with lap details
  • Training analysis
    in Suunto App
  • Training logbook with story and image support
    in Suunto App
SPORT EXPERTISE
CYCLING
  • Cycling speed
    based on GPS
  • Average speed in real time
    based on GPS
RUNNING
  • Running pace
  • Suunto FusedSpeed™
  • Average pace in real time
  • Lap comparisons by kilometer/mile
SPORT MODES
    5 modes / 4 displays per mode
Recommended products
Videos
How to change time and date settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change unit settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change vibration settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change language on Suunto Traverse and Suunto Traverse Alpha GPS watches.
Suunto Traverse's display views.
How to change display contrast on Suunto Traverse and Traverse Alpha GPS watches.
First time start up with Suunto Traverse.
Support for Suunto Traverse
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
