1 / 4
Suunto A-10 IN
Suunto A-10 IN
Suunto A-10 IN
Suunto A-10 IN
1/4
Money-back guarantee
30-Days Return
Global Support
SKU: SS012063013
Suunto A-10
IN
A robust, easy to use compact compass for general recreational use.
30-Days Return
Global Support
Suunto A-10 IN
£708
Out of Stock
Made in Finland
Limited lifetime warranty
Exceptionally stable & fast needle
MINIMALISTIC BASEPLATE COMPASS FOR HIKERS AND SCOUTS
Stable operation
The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
Detachable snap-lock lanyard
The lanyard with wristlock is easy to detach for working with the map.
Made in Finland
All Suunto compasses are handcrafted at our factory with 100% renewable energy.
SPECIFICATIONS
  • Measurements
    56 x 104 x 0 mm / 2.2 x 4.09 x 0 "
  • Weight
    30 g / 1.06 oz
  • Bezel material:
    Plastic
  • What's in the box?
    Suunto A10 IN, Lanyard and quickrelease, manual
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Plastic
  • Imperial scales
    inch, 1:24 000 mi, 1:62 500 mi, cm
  • Declination correction
    fxed scale
  • Balanced for northern hemisphere
  • Weight
    30 g / 1.06 oz
  • Water resistance
    insensitive to water pressure
  • Battery type
    no battery required
  • Lanyard quick release
  • Attachment
    lanyard
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
COMPASS
  • Direction scale
    degrees
  • Needle
    high grade steel
  • Liquid filled and jewel bearing
  • Compass accuracy
    2.5°
  • Compass resolution
