Suunto EON Core
White
A compact dive computer with an easy to read color screen, rechargeable battery and wireless connectivity with Suunto app and Suunto Tank POD. Made in Finland.
Choose Your Color
Customizable
Digital compass
Wireless tank pressure
For all diving
Wireless mobile connection
Outstanding readability with great versatility
The compact Suunto EON Core is a great dive companion whether you are just beginning diving or an active diver exploring new depths. The key details of your dive are easy to read from the clear color display with large, prominent digits. This fully featured and versatile dive computer is your reliable partner no matter if you’re exploring shipwrecks or admiring the colorful marine life.
BENEFITS
Easy to read
Grows with you
Compact and comfortable
Connect and transfer
SPECIFICATIONS
Weight154 g / 5.43 oz
Bezel material:Composite
Glass material:Mineral crystal
Case material:Reinforced composite
Strap material:Elastomer, Bungee
What's in the box?Suunto EON Core White, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialComposite
Glass materialMineral crystal
Case materialReinforced composite
Strap materialElastomer, Bungee
Flip display✔
Water resistance80 m (ISO 6425, EN 13319)
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock1 daily alarm
Stopwatch timer✔
LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TW, ZH
BacklightLED
Configurable backlight✔
Display typecolor TFT
Display resolution320 x 240
Metric and imperial units✔
Battery indicatoricon + dive hours remaining
PHYSICAL SPECIFICATIONS
Operating temperature0° C to +40° C / +32° F to +104° F
Storage temperature-20 ° C to +50 ° C / -4° F to +122° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
COMPASS
Digital compass✔
Tilt compensationup to 45°
Declination correction✔
Direction scaledegrees
Needlecompass rose
Bearing lock with direction indicator✔
Globally balanced✔
Compass accuracy+/- 15°
Compass resolution1°
CONNECTIVITY
Connectivity (between devices)inductive (up to 20 Tank PODs), Bluetooth Smart
Compatible with Suunto app✔
Compatible with SuuntoLink✔
Compatible with DM5✔
Log transferBluetooth Smart / USB cable
Smartphone compatibilityMost common models supported
OUTDOOR FUNCTIONS
WEATHER
Temperature✔
Temperature display range-20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F)
Temperature resolution1° C / 1.5° F
DIVING FUNCTIONS
BASIC
Altitude adjustment0 - 300 m / 300 -1500 m / 1500 - 3000 m
Ascent time display0 - 999 min ( > after 999)
CNS/OTU (OLF) calculation✔
Custom displays4 per dive mode
Decompression modelSuunto Fused™ RGBM 2
Decompression profile optionscontinuous and stepped
Deep Stop✔
Dive historylifetime
Dive time0 to 999 min
Gas consumption (real-time)✔
Gas max pO2manual 0.5 - 1.6 / fixed 1.6
Gas switching✔
Gas time✔
Gasesup to 10 gases (Oxygen 5 - 99% / Helium 0 -95%)
Gauge✔
Logbook bookmarks✔
Logbook memory200h or 400 dives which comes first
Logbook sampling rates10 s
Maximum operating depth (EN 13319)80m
Nitrox (and air)✔
No fly time✔
No-decompression planner✔
Personal adjustmentP+2, P+1, P0, P-1, P-2
Rebreather (CCR), fixed point✔
Safety Stop✔
Surface time0 to 100 h
Timer✔
Trimix (mixed gas)✔
Visual styleClassic/Graphical/Prominent
Wireless air integrationoptional (up to 20 different tanks with Suunto Tank POD)
DIVE ALARMS AND NOTIFICATIONS
CNS/OTU (OLF) 80% / 100%✔
Decompression ceiling violation✔
Deepstop violation✔
Diluent high pO2✔
Diluent low pO2✔
Diluent switched automatically✔
Dive time✔
Gas time✔
High pO2 (hyperoxic)✔
ICD warning✔
Low pO2 (hypoxic)✔
Maximum depth✔
Switch gas (better gas is available)✔
Tank pressure✔
Too fast ascent✔
REBREATHER
Diluentsup to 10 diluents (Oxygen 5 - 99% / Helium 0 - 95%)
Bailout✔
High/low setpoints✔
Custom setpoint✔
Manual/automatic setpoint switching✔
