Suunto A-30
NH Metric Compass
A compact, accurate compass for hiking and orienteering, also in poor visibility
Choose your Color
BASEPLATE COMPASS WITH MAGNIFYING LENS FOR BACKPACKERS
Suunto A-30 is a reliable baseplate compass for navigating and surviving in extreme conditions. Depending on the variant, A-30 comes with Metric UTM scales and inch ruler or USGS UTM scales.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
SPECIFICATIONS
Measurements57 x 114 x 10 mm / 2.24 x 4.49 x 0.39 "
Weight32 g / 1.13 oz
Bezel material:Plastic
What's in the box?Suunto A-30 NH Metric Compass, lanyard, Quickrelease, Quick Guide
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialPlastic
Metric scalescm, 1:25 000 km, 1:50 000 km
Declination correctionfixed scale
Balanced for northern hemisphere✔
Water resistanceinsensitive to water pressure
Battery typeno battery required
Luminous markingsbezel, orienting markings and direction of travel
Lanyard quick release✔
Attachmentlanyard
PHYSICAL SPECIFICATIONS
Operating temperature-30° C to +60° C / -22° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
COMPASS
Direction scaledegrees
Needlehigh grade steel
Bearing lock with orienting indicator✔
Liquid filled and jewel bearing✔
Compass accuracy2.5°
Compass resolution2°
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Magnifying lens✔
