Suunto A-10 NH Compass
A robust, easy to use compact compass for general recreational use.
Choose Your Color
MINIMALISTIC BASEPLATE COMPASS FOR HIKERS AND SCOUTS
Fast, simple and accurate, A-10 baseplate compasses are quick to learn and ideal for navigating with a map and compass. For calculating the distances, A-10 has both metric and imperial scales printed in red to stand out on topographic map.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To overcome this, A-10 has two variants with needles balanced for either the northern or southern hemisphere.
The Earth’s magnetic field does not flow evenly between the magnetic poles along the surface of the planet. To compensate for the natural tilt in the magnetic field, Suunto compasses use one of two balancing systems and you should choose the variant best serving your needs.
One is a two-zone system with needles balanced for either the northern or southern hemisphere. The second is a unique globally balanced system. A single needle is balanced to work anywhere in the world. This is achieved by a breakthrough construction allowing the needle and magnet to tilt independently.
Sustainable design from Finland
Suunto compasses are born from a legacy of Finnish innovation, crafted with precision and reliability that has guided adventurers since 1936. Designed and manufactured in Finland, each compass reflects Suunto’s commitment to quality, durability, and environmental responsibility. Made with 100% renewable energy, our compasses are built to last ensuring they remain a trusted companion for years of exploration.
For greater transparency, we’ve calculated a category-level carbon footprint for selected field compass models, representing the average climate impact of a compass in this category.
Read more about our climate actions and purchased voluntary carbon credits.
SPECIFICATIONS
Measurements56 x 104 x 10 mm / 2.2 x 4.09 x 0.39 "
Weight30 g / 1.06 oz
Bezel material:Plastic
What's in the box?Suunto A-10 NH Compass, lanyard, Quickrelease, Quick Guide
Country of manufactureFI
TECHNICAL SPECIFICATIONS
Bezel materialPlastic
Metric scalescm with distance helpers
Imperial scalesinch with distance helpers
Declination correctionfixed scale
Balanced for northern hemisphere✔
Water resistanceinsensitive to water pressure
Battery typeno battery required
Lanyard quick release✔
Attachmentlanyard
PHYSICAL SPECIFICATIONS
Operating temperature-30° C to +60° C / -22° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
COMPASS
Direction scaledegrees
Needlehigh grade steel
Bearing lock with orienting indicator✔
Liquid filled and jewel bearing✔
Compass accuracy2.5°
Compass resolution2°
