Suunto Blog
Run Your Own Virtual UTMB with Suunto
The 171-km race around the Mont Blanc massif is the most prestigious trail ultra in the world. With the new SuuntoPlus sports app, you can test the challenge wherever you are! The Ultra-Trail du Mont-Blanc (UTMB) is one of the most prestigious and challenging trail running races globally. Its origins are rooted in the desire to create a race that encapsulates the grandeur and difficulty of running through the mountainous terrain surrounding Mont Blanc. The first race was held in 2003. This year, runners will line up for the start at Place du Triangle de l'Amitié in the heart of Chamonix on August 30. It can be hard to grasp how long the race actually is. To give you a feeling of the challenge, we have created the Virtual UTMB SuuntoPlus sports app that tracks your cumulative progress towards completing the legendary route. Whether you are looking for a fun way to motivate yourself or aiming to one day run the race yourself, this sports app is for you! The Virtual UTMB sports app shows your progress towards running the distance of the 171 km Ultra Trail du Mont Blanc: the top row shows your total distance and progress towards the goal, below you see your current activity distance and duration. Here’s how it works: Go to the SuuntoPlus Store in the Suunto app and sync the Virtual UTMB sports app on your watch. Before starting your next run, go to ‘exercise settings’ and select the Virtual UTMB sports app in the SuuntoPlus section. Start your activity. The Virtual UTMB sports app will be added as an extra screen. You will be notified as your reach the distance to various aid stations on the course. The next time you use the same sport mode, the Virtual UTMB sports app will be there by default and keep adding distance towards your cumulative total of 171 km – the distance of the Ultra-Trail du Mont-Blanc. Suunto is the official technical partner of the UTMB World Series. Learn about the races at utmb.world.
SuuntoClimb,SuuntoRunAugust 21 2024
Suunto’s Climb Guidance prepares you for the terrain ahead
Want to know what kind of terrain you will face when heading into hilly or mountainous areas? The Climb Guidance in the Suunto app and Suunto watches is here to help! The route altitude profile in the Suunto app and as part of route navigation in Suunto watches has taken a major step forward. With the release of Suunto Race S, we brought the new Climb Guidance also to Suunto Race, Suunto Vertical, Suunto Ocean and Suunto 9 Peak Pro GPS watches (software version 2.35.34 or later). It will help you both in the route planning phase and out on the trails. Use it to optimize your pacing, make your race-winning moves, or simply enhance your outdoor experience.   Learn the climbs while planning The elevation profile grows in real-time as you plan your route. Color codes on the elevation profile match the colors on the map.   When planning a route in the Suunto app, the route is split into sections – climbs, uphills, downhills, descents, and flats. These sections are visualized with color coding both on the map and in the altitude profile below. A climb is marked in red, uphill in orange, downhill in lime, and descent in green. Flats are marked in blue. The section categories consider the length and steepness of the ascent (or descent). In the categorization, climbs are harder than uphills and descents are bigger than downhills. The elevation profile of your route keeps growing in real-time as you plan your route. Already in the planning phase, you can scrub the altitude profile and see where each point is on the map. This is a useful way to get to know the route you are planning to navigate.   Get alerts and zoom in on the details during activity   Overview of the elevation profile (left) and a zoomed in climb section (right).   The Climb Guidance sections are synced to your watch along with the route you planned. When you start navigating the route, by default you will see the route on one screen and an overview of the elevation profile on the next. You can zoom in on the elevation profile using the digital crown on the Suunto Race and Race S watches. On the Suunto Vertical and Suunto 9 Peak Pro, press the upper button to zoom in and long press it to zoom out. (Tip: Similarly, you can zoom in and out on the map view. The zoom-out level was updated to 20km in this latest software update.) When you zoom in from the elevation profile overview, you will see the current section in more detail. You will, for example, see the ascent covered and ascent remaining on that section along with your position on the elevation profile.   A notification 100 meters before the start of a new section (left) and a full-screen notification with details as the section starts (right).   When you are approaching a climb, a notification is given to you 100 meters in advance. As the section starts, you will get a full-screen notification with section details (vertical, distance, gradient). You will get a similar notification before a descent. Notifications are not triggered for uphill, downhill or flat sections of the route. Climbs are categorized on a scale of 1–4 and HC (hors categorie) based on their difficulty. The section notifications can be turned off in the exercise settings. Before starting an activity, go down to exercise settings and select ‘Climb Guidance’. You can then toggle the notifications off and on. You can also select whether you want to see the gradients in percentages or degrees. By default, the gradient is shown in percentages. The climb notification and grade settings are persistent per activity type; they are automatically remembered the next time you start the same activity.
SuuntoClimbJuly 05 2024
Suunto Vertical keeps evolving
Follow the latest updates and developments of your Suunto Vertical GPS watch and enjoy it to its full potential. On this page you can see in a timeline view how your Suunto Vertical has evolved since it was launched in June 2023. To always have the latest watch software, we recommend you enable automatic, over the air software updates in the watch settings. Also, make sure you are using the latest version of Suunto app for iOS or for Android. You can find dozens of SuuntoPlus sports apps in Suunto mobile app’s SuuntoPlus Store and the ever-growing list of Suunto compatible partner services is here.   March 2024 The new Vertical Week sports app was published to SuuntoPlus Store. The SuuntoPlus Vertical Week sports app can be used to track the total elevation gain of multiple workouts during the week. Learn more about Suunto World Vertical Week 2024. Pace your mountain races with SuuntoPlus Vertical Race sports app. The Vertical Race sports app is designed to be used on vertical races. Set you race distance, vertical meters and goal time and follow the pace data live on your Suunto. Follow and improve your running technique with Stryd SuuntoPlus sports app. The Stryd sensor provides data such as ground contact time, vertical oscillation, leg stiffness and impact loading rate. Read more about improving your running technique with Suunto and Stryd here For ultrarunners, there is now an Ultrarun& walk SuuntoPlus sports app that will track how much one runs, walks, or stays still on the race. The app helps you to pace & analyse long efforts. This sports app has been built by trailrunner Alessio Sclocco who is also part of Suunto fieldtest community. A software update for Suunto Vertical, Suunto Race and Suunto 9 Peak Pro was released. The update delivered three new watch faces, better support for emojis in mobile notifications and a pause reminder. The update also provided navigation enhancements with improved high contrast map style for use with always on display and a new ruler tool to measure distances on map to nearby locations. Suunto app was updated with performance improvements to data sync between watch and Suunto app and a user interface change to how workout summary values are shown in the app. New Suunto connected partner services include Base de Vitesse aimed for surfers and sailors, Be Number one sport for competing in your sports, MoveEffect aimed for corporate health and Mia Health to engage in your fitness journey. You can find the latest list of partners from here   February 2024 New Winter maps map layer with downhill and cross-country skiing tracks came available in Suunto app to help you find the best places to ski. Waypoint import was improved for GPX route import with better waypoint compatibility with route planning services. Training Zone Summary now shows swim pace, average power and normalised power. Performance improvements to data sync between watch and Suunto app Suuntoplus Power Zones and Pace Zones sports apps were published for runners and riders. Now you can follow the cumulative time in each zone and see which zone you currently are working out.  Suunto is now compatible Xioami MiFitness. Xiaomi users can now connect their devices with Suunto via Mifitness app. This gives the possibility to use Suunto app tools as well as get connected with Suunto ecosystem. Read more here.   January 2024 Race with the new SuuntoPlus Race Pacer sports app. Set your target distance and time with even or negative splits. Now you can follow your Runna training plans in your Suunto watch FIT-UP app is now suunto compatible, designed for fitness, nutrition and mindfulness Suunto app calendar view now includes date numbers, offering a clearer overview of your training schedule. New interactivity in Suunto app route planning: touch the altitude profile chart to see corresponding locations on the map. Sleep analysis in Suunto app has been upgraded to support multiple naps within a single day, giving you a more comprehensive understanding of your rest patterns. Switching between the data table and graph in Suunto app’s Training Zone Summary is now more intuitive and user-friendly. Suunto app now remembers your last used settings for feed filtering (All/Me/Following) and your preferred Training Zone tab and graph types, making your experience more personalized and efficient. In the Training Zone Summary, selecting categories like All running sports, All cycling sports, and All swimming sports is now simpler. You can choose these categories without having to select each sport individually. We've fixed formatting issues in SuuntoPlus data, ensuring more accurate and readable information. We have also made several other bug fixes and performance improvements to ensure a smoother and more reliable experience.   December 2023 Better Training analysis Suunto app’s Lap Table now features color-coded columns. Variations from the median lap values are highlighted in shades of red and blue. This color-coding makes it easier to spot laps where your performance was significantly higher or lower than median. We’ve introduced zone graphs for Pace and Power in the workout analysis. These graphs are complemented by a distribution view of pace and power zones, providing a more intuitive understanding of your workout intensities. With Training Zone Summary you can now visualize your selected data through a graph. Summary also includes filters for both automatically and manually tagged workouts. For added convenience in filtering, options such as “All running” or “All cycling” are available, enabling you to select all activities under these categories effortlessly. Plan your adventures with Suunto App Suunto App Route planning has received new features: the ability to reverse planned routes and the addition of “Back to Start” and “Backtrack” options, enhancing your planning capabilities. User experience enhanced. New defaults Sport apps preinstalled to sport modes. When you, as an example, start your tennis workout, it already has tennis sport app, and weight training has Gym Timer. Suunto App has now streamlined the recovery features by combining the Recovery and Sleep tabs into a single, unified Recovery tab, simplifying access to your recovery and sleep data Celebrate the end of the year with your achievements with Annual report in Suunto app and share the updated yearly summary also in story format (9:16). Get more out of your sports with new partners RaceID miles partner app gets Suunto compatible Runology running technique video analysis gets Suunto compatible Runredeem is now Suunto compatible with their loyalty program customers Surlo app for sailing and other water sports gets Suunto connected Get more out of your Indoor cycling training with Suunto compatible ICTtrainer Ride with BMC companion app which is now Suunto compatible   November 2023 Training, recovery and progress come to your watch, including Heart Rate Variability (HRV) Follow training load and volume with training widgets in your watch. Follow recovery status from training with TSB and feeling in your watch. Measure Heart rate variability (HRV) to optimize your recovery. Follow your progress with chronic training load (CTL) widget. Get Suunto Coach comments in training widgets. Exercise with new rope skipping activity type. Read more: How to use HRV to optimize your recoveryHow to follow your progress with Suunto Training with TSS Follow Training load Must-read articles that guide you into Suunto’s world of training   The watch now fits better to your daily life New UI structure with mini widgets Customization of the widgets using Suunto app: Select the widgets you want to have on your watch and change the order they are shown. Improved the watch user interface speed A higher zoom level on the maps ‘Find my phone’ feature on your watch Do not disturb mode New media controls Multiple alarms   New connections KML file import in Suunto app Suunto Vitality compatibility now includes AIA Malaysia   October 2023 Better Training analysis Follow the training impacts of workouts in Suunto app SuuntoPlus Vertical race segment guide available in SuuntoPlus Store for Malaysian Suunto fans.   Enhanced user experience The Suunto App home screen can now be filtered with all, me or following. New, colourful Suunto accessory straps   September 2023 New tools to understand you training impact and intensity Training summary: A tool to analyse & find your key workouts in Suunto app. Go to Training Zone tab and check the Summary. Movement: Track your movements with wrist acceleration to follow the overall workout intensity. Gets you the insights of rapid efforts. Heart rate zones: Follow the cumulative time spent on different heart rate zones on one screen. Great to keep the intensity on target. Fused zones: Shows which intensity zone you are currently in, looking at different intensity metrics and based on that evaluating the best matching as a result. Peak Pace: Track the peak pace efforts on your run. Peak power: Track the hard sprints and efforts on your wrist. Plan better Interval planner: Use the Interval planner in Suunto app now with all activity types. Prepare for optimal race Race nutrition: Plan your race nutrition and get reminders right on your Suunto. Race companion: A simple, customizable tool that shows you the key information during a race. Backyard ultra: Race companion for Backyard Ultra racers. Follow each 6.7km loop and keep track of the laps – and when to go next! Get most out of your sport Gym Timer: Follow the recovery time between the sets. Adjust as needed and then go again. Score – Golf: Count each strike and measure the distance of the drives with the Golf Score sport app. Score – Tennis: Keep count of the game score on your wrist. Score – Soccer: Keep up with the game score and get alerted with the half time. Score – Badminton: Keep up with the badminton game score. Score counter: Counter for any game. Play with 1–4 players and keep the results on your wrist. Learn more: Discover dozens of SuuntoPlus sport apps for your Suunto   July 2023 New sensor compatibility Train.red: Connect your Suunto with a Train.red sensor to follow your muscle oxygen levels. The data will also be available in after analysis.   June 2023 Strava updates In addition to syncing your activities to Strava and using Strava routes with your Suunto watch, you can now also race Strava Live Segments with your Suunto. Learn how to chase Strava segments with your Suunto Get more out of your sports Surfer: Count each wave surfed automatically. Each wave is also stored as laps in your surf session. Running economy: Follow the running economy with heartrate vs. pace. Running economy is illustrated with a beats/km value. Shoe Tester: Follow test protocol to test different shoes to see which are the fastest for you. Disc Golf: Keep track of each disc golf throw and see the distance thrown. Get ready for the outdoors Weather forecast sports app: Keep the forecasted weather on our wrist while doing the long ride or hike. ICE: Store your emergency information on your wrist. If you don’t move the watch, it will start an alert to draw attention to the info. Relief Maps: Gets Suunto connected with 3d maps and live data sharing for outdoor enthusiast. Join challenges with Uprace App Race in Virtual Races Tackitup app Suunto Weekend Adventure collections published in Komoot
SuuntoClimb,SuuntoRide,SuuntoRun,SuuntoSki,SuuntoSwimJune 07 2024
Italy dominates the Vertical Week 2024
Suunto World Vertical Week, the thrilling celebration of the uphill challenge, united outdoor enthusiasts from around the globe in a collective pursuit of elevation gain on March 18–24. All human-powered activities by the participants were counted and every hill was turned into an opportunity to conquer new heights.  We have now analyzed the data to see which country and activity type climbed the most!   The usual suspects were on top of the country rankings In the country rankings, the usual suspects – countries in the mountainous regions of Europe – were once again on top. This time Italy dethroned Austria for the number one spot with over 400 meters of ascent per activity on average. Switzerland also broke its way to the top three. The only non-European nation in the top 10 was South Africa in ninth place. Greece made it to the top 10 for the first time.   Average ascent meters by country   When looking at the total ascent, meaning adding up the ascent in all the activities in a nation for the Vertical Week, France took the top spot from Spain and Italy climbed past Austria on the third spot. Top 10 for total ascent meters France Spain Italy Austria Germany Switzerland USA Poland United Kingdom Czech Republic   Skiers – and the Japanese trail runners – were above the rest In the activity type rankings, there weren’t any major changes: ski touring activities had the biggest average ascent, followed by mountaineering and trail running. The average ascent for all the ski touring activities came close to the magical 1000-meter mark but was still a bit below the summit. Maybe next time!   Average ascent meters by activity type   While the skiers had the biggest days on average, when looking at individual activities with over 1000 meters of ascent, trail runners were in the lead. In 2023 the order was the other way round. In the individual performances, four people really stood out: They all had tracked over 20.000 meters of human-powered ascent during the Vertical Week. Impressive! And while looking at the big picture, many people seemed to push it more than last year: For a top 10% placing, you needed to climb 2275 meters during this year’s Vertical Week. That’s almost 373 meters more than in 2023. The same change is visible in the top of the top: To make it to the top 3% of the Vertical Week participants, you needed to climb 4062 meters, 472 meters more than in 2023. The country rankings winner Italy is very strong also in different activity type rankings. They earned a podium spot in six out of ten different categories! Ski touring Slovakia 1160m Switzerland 1062m Poland 1051m(Average for all countries 953 m) Whoop whoop, we have a new winner in the ski touring category! The Slovakian skiers ascended more than any other nation in any of the categories. It’s also clear that the 1000-meter mark is a clear goal for skiers, and the entire top 3 broke that limit. Trail running Japan 1076m Italy 674m Greece 600m(Average for all countries 457 m) This is amazing: The Japanese trail runners were the only ones breaking the 1000-meter mark in any other category than ski touring. They kept their well-deserved top spot in trail running for another year. Congratulations! Mountaineering Italy 865m Finland 838m France 799m(Average for all countries 633 m) Italy continued their dominancy, but the second place was a surprise: How did such a flat country as Finland make its way to second place? Mountain biking South Africa 645m Italy 547m Slovenia 540m(Average for all countries 393 m) The South Africans were active on the bike, climbed more than any other nation and ensured that also the African continent was presented in the rankings. Gravel cycling United Kingdom 656m United States 440m Italy 421m(Average for all countries 298 m) Gravel cycling was a new addition on the list this time. And, not surprisingly, the ascent meters for gravel cycling fell somewhere between mountain biking and cycling. The UK took the top spot in the activity ranking clearly. Cycling Spain 435m Italy 335m Slovenia 286m(Average for all countries 210 m) Everyone knows that cycling in Spain in the spring is great. And they seem to know it themselves, too! Trekking Japan 850m Switzerland 575m Austria 541m(Average for all countries 351 m) The Japanese took the top spot in two categories, trekking and trail running. Two category wins was only matched by Italy (number one in mountaineering and hiking). Hiking Italy 438m Slovakia 386m Slovenia 351m(Average for all countries 240 m) Yet another category with a strong Italian performance. Forza! Nordic skiing Switzerland 363m Austria 324m Norway 305m(Average for all countries 216 m) While the top three countries in the cross country skiing category were expected, what was surprising was the change in the podium lineup from the previous year: None of these three were on the podium last year. Running Czech Republic 152m Switzerland 138m South Africa 130m(Average for all countries 95 m) Running, the most popular Suunto activity in general, is not focused on the vert. Despite the smaller numbers, there still is a winner: Czech Republic took the number one spot!
SuuntoClimb,SuuntoRide,SuuntoRun,SuuntoSkiApril 09 2024
Celebrate the uphills during the 10th annual Suunto World Vertical Week!
Some people choose the path with the least resistance. We choose to celebrate the uphills. Join us for the 10th annual Suunto World Vertical Week on March 18–24! Welcome to Suunto World Vertical Week – a thrilling celebration of the uphill challenge! From March 18 to March 24, outdoor enthusiasts from around the globe will unite in a collective pursuit of elevation gain, turning every hill into an opportunity to conquer new heights. The beauty of Suunto Vertical Week lies in its accessibility, taking place everywhere, and embracing all human-powered activities. Whether you're a trail runner, skier, hiker, mountaineer, cyclist, or any other adventurer, the Vertical Week invites you to climb as much as you can. The ultimate goal? To determine which nation and activity type emerges victorious, boasting the most elevation gain. Joining the Vertical Week is simple – just open the Suunto app and click 'join' in the Vertical Week message. All your human-powered activities during the week count. Join now and elevate your adventure! Follow your progress in real-time The Vertical Week sport app shows the current activity ascent (top), total ascent (bottom) and your total compared to Vertical Week participants in 2023.   You can follow your total ascent for the Vertical Week with the new SuuntoPlus Vertical Week sport app: The Vertical Week sport app will count every meter you climb and show your cumulative ascent for both the current activity and the entire week. You can also see how high you would be ranked in the previous Vertical Week challenge. Are you already in the top 30% or perhaps even the top 5% of participants? Go to the SuuntoPlus Store in Suunto app and sync the Vertical Week sport app to your watch. Before starting your first activity of the Vertical Week, select the sport app in the activity settings. Learn more about SuuntoPlus sport apps.    Join our community events in Innsbruck and Girona If you are spending your Vertical Week in or around Innsbruck, Austria, or Girona, Spain, you should check out our community events: In Innsbruck we will be running with BASEFIVE on March 18 and skiing on March 20 and 23. In Girona we will go on a community run together with the Overland crew on Saturday, March 23.  Learn more about Suunto x OVERLAND Vertical Week events in Girona and join!   Data from previous years Check out which sports and nations have captured the podium places during the past years. Will this year bring changes to the top places? Now is your chance to affect on this year's results by collecting as many vertical meters as possible.  2023 - 2022 - Summer 2021 - Winter 2021 - 2020 - 2019 - 2018 - 2017 - 2016   Read more How to use the terrain maps in your Suunto Vertical 10 Suunto features for vertical gain Suunto World Vertical Week 2023 Big Data
SuuntoClimb,SuuntoRide,SuuntoRun,SuuntoSkiMarch 12 2024
7 adventure films to watch during the holidays
Race to the Summit Two years ago, Dani Arnold completed the biggest project of his life: climbing the six large Alpine north faces – alone and in record time. The project occupied, accompanied and shaped him over a period of 10 years. Now the Netflix is devoting a 90-minute report to three of these climbs. Race to the Summit features the dizzying feats of Dani Arnold and the late Ueli Steck, two great Swiss alpinists and long-time Suunto ambassadors. Experienced mountaineers need a day or more to climb the infamous north faces of the Eiger or Matterhorn. But Dani and Ueli climbed them alone in less than three hours. The duel thrilled the climbing world and electrified the media. Watch the trailer above and the full film on Netflix.   Lost Then Found TDS winning athlete Christian Meier shares his inspiring story in Lost Then Found. Christian started his athletic career as a cyclist and has since made a transition from the pro peloton to the top of ultra-running. ”Life is a constant evolution of who you are as a person and Lost Then Found marks an important turning point in my life not only as an athlete but as an individual. From losing cycling to finding trail running this is a story of self-discovery and I am happy to be able to share that journey,” says Christian.   Arctic Lines – Sunny Car Center In the Arctic Lines video series, backcountry snowboarder Antti Autti explores the vast wilderness of northern Finland, Sweden, and Norway. The series is now in its third season, and in the latest episode, 'Sunny Car Center,' Antti seeks—and finds—a new special zone in Northern Norway. ”Exploring expands your horizons and finding new locations is one of the most important aspects of freeriding,” says Antti.   Balkan Express Ski mountaineers Jochen Mesle and Max Kroneck rode 2500 km from Greece to Germany – and stopped to ski along the way. Balkan Express, their film about the adventure, has won acclaim at international film festivals. “We really wanted to experience some mountains, cultures, people we didn't know. We looked at a map of Europe and saw that the Balkans are pretty interesting. The sport side wasn’t the main focus of the project. It was about getting to know the culture and people,” says Max.   Nomadland – Bikepacking in Mongolia Alba Xandri and Erreka Calmet found beautiful landscapes, friendly people and an epic adventure while bikepacking in in the Mongolian grasslands – and made a film about it. ”Mongolia far exceeded our expectations. It is a backcountry bikepacker’s paradise,” says Alba.   Ride to Ski – Bikepacking adventure through the Dolomites Lack of snow forced Henna Palosaari to think outside the box and led her to invite two of her friends, Sami Sauri and Malva Björkman, on a bike & ski adventure. The 9-day journey that combined two of her favorite sports, turned out to be a beautiful mix of sweat, laughs, ice, snow, and friendship.  ”It wasn’t a pure sufferfest,” Henna laughs.   Max Ammer, Raja Ampat and the richest reefs in the world This is an oldie but goldie: Max Ammer, founder of Papua Diving and two Eco Resorts, Sorido Bay and Kri Eco Resort, shows us why these incredible projects are more than just places to stay, dive and enjoy the unique ecosystems. Over the past 30 years, a remarkable conservation project has unfolded. The local team, with unwavering dedication, has prioritized the protection of the flourishing ecosystem. This strategic focus has proven to be wise, as the tangible outcomes of their hard work, long-term planning, and precise execution are evident in the thriving fish and coral counts. This stands as a rare case where the reefs are experiencing unprecedented richness – and gives hope for other areas as well.   Lead image by Richard Bucher / Ride to Ski
SuuntoClimb,SuuntoDive,SuuntoRide,SuuntoRun,SuuntoSkiDecember 22 2023
