Suunto Traverse Alpha Stealth
GPS/GLONASS watch with versatile outdoor functions for fishing and hunting
      24.300 Kč
        Go explore
Traverse Alpha combines strong build quality with a full set of outdoor features. It is your guide in the wild, keeping you on track with GPS/GLONASS navigation. Specific fishing and hunting features provide useful tools for your activity, including moon phase calendar, shot detection, sunrise alert, weather trend, and red backlight for nighttime use. Plan your routes and keep a diary of your fishing and hunting trips with Suunto Movescount.com. The strap pattern in Traverse Alpha Woodland draws inspriration from the camouflage pattern used by the Finnish military.
PRODUCT HIGHLIGHTS
- Master your territory with GPS/GLONASS navigation
 - Made in Finland, tested to military standards
 - Dedicated functions for fishing, hunting and hiking
SPECIFICATIONS
                  Measurements50 x 50 x 15 mm / 1.97 x 1.97 x 0.59 "
                  Weight75 g / 2.65 oz
                  Bezel material:Stainless steel
                  Glass material:Sapphire crystal
                  Case material:Composite
                  Strap material:Textile
                  What's in the box?Suunto Traverse Alpha Stealth, USB cable, quick guide, warranty leaflet
                  Country of manufactureFI
TECHNICAL SPECIFICATIONS
                      Bezel materialStainless steel
                      Glass materialSapphire crystal
                      Case materialComposite
                      Strap materialTextile
                      Flashlight backlight option✔
                      Vibration alert✔
                      Water resistance100 m
                      Battery typerechargeable lithium-ion
                      Firmware upgradable✔
                      Time, date✔
                      Alarm clock1 daily alarm
                      Dual time✔
                      Automatic timekeeping✔
                      Countdown timer✔
                      Stopwatch timer✔
                      LanguageEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
                      BacklightLED
                      Configurable backlightcolor / brightness / mode
                      Button lockcustomizable
                      Invert display✔
                      Display typematrix
                      Display resolution128 x 128
                      Metric and imperial units✔
                      Automatic daylight saving time✔
                      Battery indicatorpercentage / icon
                      Memory left indicator✔
PHYSICAL SPECIFICATIONS
                      Operating temperature-20° C to +60° C / -5° F to +140° F
                      Storage temperature-30° C to +60° C / -22° F to +140° F
                      Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
                      In time mode14 days
                      Training mode with GPS10, 15, 100 h For more information www.suunto.com/software-updates
COMPASS
                      Digital compass✔
                      Tilt compensationfull
                      Declination correction✔
                      Direction scaledegrees / mils
                      Needlenorth indicator
                      Bearing lock with direction indicator✔
                      Compass accuracy5°
                      Compass resolution1°
CONNECTIVITY
                      Connectivity (between devices)Bluetooth Smart
                      Watch customizationUSB cable
                      Data transferWireless / USB cable
                      Phone notifications on the watchwith Suunto App
                      Compatible with online sports communitiesStrava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
                      Smartphone compatibilityMost common models supported
SUUNTO APPS
                      Compatible with Suunto Apps✔
                      Max. nr. of apps per sport mode4
                      Logging of app specific metrics✔
                      Most recommended apps by activity✔
                      Create own metrics with advanced formulas✔
                      Chrono, GPS, HR, weather and altitude data✔
                      Rich math functions, if/then-logic, sound, backlight, etc.✔
24/7
ACTIVITY TRACKING
                      Step counter✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
                      Satellite systemsGPS, GLONASS
                      GPS recording rateBest, Good, OK
                      Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
                      Waypoint and visual route navigation✔
                      Max. nr. of Points of Interest (POIs)250
                      Find back✔
                      Breadcrumb trail in real time✔
                      Route planning with altitude profilein Suunto Movescount.com
                      Route altitude profile navigation in real-time✔
                      Route points per route / POIs in watch1000 / 250
                      GPS track analysisin Suunto App
                      Track backyes, incorporated with breadcrumb trail
                      Track logging, viewing and sharingin Suunto App
                      Route planningin Suunto Movescount.com
ALTIMETER
                      Barometric altitude✔
                      Altitude graph✔
                      GPS altitude✔
                      Combined GPS and barometric altitude (FusedAlti™)✔
                      Altitude differencein log summary, and real time as an App
                      Total ascent/descentair pressure based
                      Vertical speedair pressure based
                      Automatic alti/baro profile✔
                      Log recording rate1, 10 s
                      Resolution1 m
                      Range-500 - 9999 m
WEATHER
                      Sunrise/sunset times✔
                      Storm alarm✔
                      Sea level pressure✔
                      Temperature✔
                      Temperature display range-20° C to +60° C / -4° F to +140° F
                      Temperature resolution1°
                      Pressure resolution1 hPa / 0.03 inHg
                      Max weather recording lengthpast 26 hours
                      Moon phase calendar✔
                      Sea level pressure graph✔
                      Tide informationyes** ** available as Suunto Apps
                      Weather trend indicator✔
TRAINING FUNCTIONS
HEART RATE
                      Heart rate in beats per minute✔
                      Records heart rate in swimmingyes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
                      Calories✔
                      Heart rate in % of max hr✔
SPEED AND DISTANCE
                      GPS speed and distanceIntegrated
                      Chrono✔
                      Distance based autolaps✔
                      Laps> 1000
                      Autopause✔
TRAINING LOAD
                      Log summary on the watch with lap details✔
                      Training analysisin Suunto App
                      Training logbook with story and image supportin Suunto App
SPORT EXPERTISE
CYCLING
                      Cycling speedbased on GPS
                      Average speed in real timebased on GPS
RUNNING
                      Running pace✔
                      Suunto FusedSpeed™✔
                      Average pace in real time✔
                      Lap comparisons by kilometer/mile✔
HUNTING
                      Automatic shot detection✔
                      Hunting specific POI types✔
                      Moonrise / moonset alert✔
                      Moonrise and moonset times for selected date✔
                      Red backlight, compatible with night vision goggles✔
                      Sunrise / sunset alert✔
FISHING
                      Fishing specific POI types✔
                      Storm alarm✔
                      Temperature✔
SPORT MODES
                      Customizable sport modes and displays5 modes / 4 displays per mode
