Suunto Sonic
Black
Bone conduction headphones for sports.
- Open-ear design for comfort and safety
- Enhanced bass for rich sound experience
- IP55 sweatproof & water resistant
- Up to 10 hours battery & quick charge
- Lightweight for all day wear
Choose your Color
Add music to your sport
When out doing sports we have to be aware of traffic – but now you can combine those sounds with your favourite music.
With open-ear design and excellent sound quality, the Suunto Sonic bone conduction sports headphones are the perfect way to combine both.
Open for what is out there
Open-ear technology allows you to listen to music and at the same time still hear your surroundings. Instead of traditional in-ear headphones, Suunto Sonic sits on your jawbone leaving your ear canal open to stay aware of the nature or traffic around you.
Light yet powerful
Suunto Sonic does not only feature a lightweight, comfortable design but also a newly designed sound transducer. This allows for higher sensitivity, enhanced bass effect and a reduction in noise leakage.
Sweatproof, water resistant
From blazing hot to freezing cold, from getting covered in sweat to running in the rain - Suunto Sonic has an IP55 rating, so that you can enjoy your sport in all types of conditions and still listen to your favourite songs.
Lasts long, recovers quickly
Suunto Sonic comes with up to 10 hours of battery life with one charge and is fully charged in 60 minutes. If you happen to run out of power just before a workout, a quick 5-minute recharge keeps your audio going for another 3 hours.
Boost your headphones with Suunto app
Connect Suunto Sonic via Bluetooth to Suunto app on your phone to get the most out of your headphones. Change your preferred sound mode or switch the dual device connection off. With Suunto app changing settings is just a tap on the screen away.
Device controls
SPECIFICATIONS
Measurements102 x 125.5 x 46.5 mm / 4.02 x 4.94 x 1.83 "
Weight31 g / 1.09 oz
Case material:Silicone + Titanium Alloy
What's in the box?Suunto Sonic headphones, headphone charging cable, Suunto storage bag, Printed user quick guide, International warranty leaflet, Safety leaflet
Country of manufactureCN
TECHNICAL SPECIFICATIONS
Case materialSilicone + Titanium Alloy
Water resistanceIP55
Battery typerechargeable lithium-ion
Battery Charge TimeHeadphones:≤1h
Firmware upgradable✔
Music only play time≧10H (60% volume, using SBC format to play 'Hotel California')
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-20° C to +60° C / -5° F to +140° F
Recommended charging temperature0° C to +45° C / +32° F to +113° F
CONNECTIVITY
Compatible with Suunto app✔
Software updates from cloud✔
Bluetooth5.2
Bluetooth Range> 10m
Supported Audio FormatsA2DP, AVRCP, HFP, HSP
Supported Audio codecSBC, APTX Adaptive
Dual device connection✔
Smartphone compatibilityMost common models supported
SPEAKER
SizeL24.2mm*W15.1mm*H6.2mm
Impedance6Ω±15%
Frequencyrange20Hz~20kHz
Sensitivity117dB@1kHz -10dBFS
T.H.D<5% 300HZ-4kHz
MICROPHONE
Sensitivity-38dB(1kHz)
Frequencyrange100Hz~10KHz
S/N Ratio62.5dB
