Out of Stock
1 / 7
Suunto Wing Lime
Suunto Wing Bone Conduction headphones - Lime
Suunto Wing headphones - Lime
Suunto Wing Open ear headphones - Lime
Suunto Wing Bone Conduction headphones with red light for more visible
Suunto Wing Bone Conduction headphones for outdoor adventures
1/7
Photos
Video
Money-back guarantee
30-Days Return
Global Support
SKU: SS050943000
Suunto Wing
Lime
Sale priceBZ$318
Premium bone conduction headphones for sports.
  • Open-ear design for comfort and safety
  • LED lights for better visibility
  • Head movement control to free your hands
  • IP67 sweat & waterproof
  • Up to 10 hours battery + 20 hours with powerbank
  • Anti-wing noise up to 30km/h for sound clarity
Choose your Color
Quantity
30-Days Return
Global Support
Suunto Wing Lime
BZ$318
Out of Stock
Open-ear design
Head Movement Control
Anti-wind noise up to 30km/h
"They are incredibly high quality, have exceptional battery life on their own…"
roadtrailRUN
Add music to your adventure
We love the sounds of nature when out adventuring – but sometimes life is just better with music.
With LED lights, a battery life of up to 10 hours and an additional 20 hours from the external powerbank, the Suunto Wing bone conduction sports headphones are the perfect way to combine both.
Open for what is out there
Open-ear technology allows you to listen to music and at the same time still hear your surroundings. Instead of traditional in-ear headphones, Suunto Wing sits on your jawbone leaving your ear canal open to stay aware of the nature or traffic around you.
For safer adventures
Suunto Wing features red LED lights on both sides of the head, so that in dim conditions whether on the trails or on the roads you are more visible. You can choose between different light modes or turn them on/off with your Suunto app.
Hands-free operation
For the adventures that keep your hands busy, Suunto Wing comes with Head Movement Control. This feature allows you to skip to the next song or answer a phone call simply by shaking or nodding your head instead of pushing a button.
Waterproof,dustproof
From blazing hot to freezing cold, from getting covered in dust & sweat to showering it all off at home – Suunto Wing is made so you can enjoy your adventures in all types of conditions and still listen to your favourite songs.
Recharge on the go
Up to 10 hours of battery life with one charge. For those longer adventures, Suunto Wing comes with portable a powerbank that adds another 20 hours of music playtime. And if you do run out of power, a quick 10-minute recharge gives you 3 hours of audio for your training.
Boost your headphones with Suunto app
Connect Suunto Wing to Suunto app on your phone to get the most out of your headphones. Change your preferred sound mode or switch the LED lights from constantly on to a blinking mode. With Suunto app changing settings is just a tap on the screen away.
Device controls
SPECIFICATIONS
  • Measurements
    102.5 x 126.5 x 46.5 mm / 4.04 x 4.98 x 1.83 "
  • Weight
    33 g / 1.16 oz
  • Case material:
    Silicone + Titanium Alloy
  • What's in the box?
    Suunto Wing headphones, Headphone charging cable, Powerbank, Suunto storage bag, Earplugs, Printed user quick guide, International warranty leaflet, Safety leaflet
  • Country of manufacture
    CN
TECHNICAL SPECIFICATIONS
  • Case material
  • Weight
    33 g / 1.16 oz
  • Water resistance
    IP67
  • Battery type
    rechargeable lithium-ion
  • Battery Charge Time
    Headphones:≤1hPowerbank:≤1.5h
  • Firmware upgradable
  • Music only play time
    ≧10H, Used with powerbank: ≧30H (60% volume, using SBC format to play 'Hotel California')
  • Music play time after opening head movement control
    ≧8H
  • Music play time after the LED lights in the constant light
    ≧4H
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
CONNECTIVITY
  • Compatible with Suunto app
  • Software updates from cloud
  • Bluetooth
  • Bluetooth Range
    > 10m
  • Supported Audio Formats
    A2DP, AVRCP, HFP, HSP
  • Dual device connection
  • Smartphone compatibility
    Most common models supported
POWERBANK
  • Size
    93.5mm*48mm*25mm
  • Case material
    Plastic
  • Weight
    40g
  • Water resistance
    IP55
SPEAKER
  • Size
    L22.1mm*W13.15mm*H6.5mm
  • Impedance
    6Ω±15%
  • Frequencyrange
    20Hz~20kHz
  • Sensitivity
    117dB@1kHz -10dBFS
  • T.H.D
    <5% 300HZ-4kHz
MICROPHONE
  • Sensitivity
    -38dB(1kHz)
  • Frequencyrange
    100Hz~10KHz
  • S/N Ratio
    62.5dB
SUPPORT FOR SUUNTO WING
Find the full user guide and other detailed support information for your Suunto headphones.
