Out of Stock
Suunto Nautic Bungee Cord & Tank Pod
Money-back guarantee
30-Days Return
Global Support
SKU: SS051302000
Suunto Nautic
Sale priceBZ$2,350
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Coming in December
Quantity
30-Days Return
Global Support
BZ$2,350
Out of Stock
Bright AMOLED display, integrated
LED flashlight
Up to 120 hours on a single charge
Wireless tank
pressure
Multi-gas and sidemount support
GPS and underwater route tracking
Suunto App
connectivity
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed and built in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Rugged leak-proof construction
Glove-friendly
buttons
Designed and tested
in Finland
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Rechargeable battery.
single charge
Reliable power for
multi-day diving trips
Designed for endurance
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Multi-gas and
sidemount support
Customizable dive
views
Full decompression
planning
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Wireless tank
pressure readings
Dual transmitter
support for
sidemount diving
Color-coded visuals
for instant clarity
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Offline maps and GPS help plan and track your routes, while the built-in digital compass provides precise direction underwater. Tide, weather, and sunrise/sunset data support safe surface intervals and the integrated flashlight brings visibility and convenience when light is scarce. Nautic keeps you aware and in control, both underwater and on the surface.
GPS and offline maps
Digital compass for underwater
navigation
LED flashlight, tide, and weather support
for safety
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Automatic dive log
sync
Route and condition tracking
Share and relive
every dive
Explore more with the Suunto app
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Access additional benefits and services from our 200+ partners.
Learn more
SPECIFICATIONS
  • Measurements
    101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
  • Weight
    227g (with bungee strap) , 232g (with elastic textile strap)
  • Bezel material:
    Fiber reinforced polymer
  • Glass material:
    Panda glass (PANDA-MN228 high alumina silicon glass)
  • Case material:
  • Strap material:
    Bungee cord / Elastic textile
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
  • Glass material
  • Case material
  • Strap material
  • Weight
  • Color display
  • Vibration alert
  • Water resistance
    200 m
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Stopwatch timer
  • Language
  • Backlight
    AMOLED
  • Configurable backlight
    automatic brightness
  • Button lock
  • Display size
    3,26"
  • Display type
    matrix
  • Display resolution
    720x382
  • Metric and imperial units
  • Battery indicator
    percentage / icon
  • Always-on display
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Operating temperature in dive mode
  • Storage temperature
BATTERY LIFE
  • Battery life (dive)
    80-190h
COMPASS
  • Digital compass
  • Digital compass during scubadiving
  • Tilt compensation
  • Declination correction
  • Direction scale
  • Needle
  • Compass accuracy
  • Compass resolution
CONNECTIVITY
    Bluetooth
  • Compatible with Suunto app
  • Smartphone compatibility
    Most common models supported, check here for detailed compatibility list
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Offline maps on watch
  • Satellite systems
  • GNSS frequency support
    Dual band (L1+L5)
  • Offline map storage size
    32 GB
    4
  • Max connected satellites
    32
  • GPS recording rate
    Best, Good, OK, Low
  • Zoom levels in navigation
  • GPS track analysis
WEATHER
  • Sunrise/sunset times
  • Temperature
  • Temperature display range
  • Temperature resolution
    1° C / 1.5° F
TRAINING FUNCTIONS
HEART RATE
    Bluetooth HR belts
SPORT EXPERTISE
SPORT MODES
    Customizable dive
    In dive
    Dive modes
  • Suitable for sports
    Scubadive
DIVING FUNCTIONS
BASIC
  • Altitude adjustment
  • Ascent time display
  • CNS/OTU (OLF) calculation
  • Customizable dive modes and displays
  • Decompression model
    Suunto Bühlmann 16 GF
  • Decompression profile options
    continuous and stepped
  • Dive history
    lifetime
  • Dive time
  • Gas consumption (real-time)
  • Gas max pO2
    manual 1.0 - 1.6
  • Gas switching
  • Gas time
  • Gases
    up to 5 gases (Oxygen 21 - 100%)
  • Gauge
    200m
  • Nitrox (and air)
  • No fly time
  • No-decompression planner
  • Personal adjustment
    Gradient factors low (10-100) and high (50-100)
  • Safety Stop
  • Surface time
  • Timer
  • Wireless air integration
  • Wireless gas integration
  • Deco planner
  • Helium
DIVE ALARMS AND NOTIFICATIONS
  • CNS/OTU (OLF) 80% / 100%
  • Dive time
  • Gas time
  • High pO2 (hyperoxic)
  • Low pO2 (hypoxic)
  • Maximum depth
  • NDL
  • Tank pressure
  • Too fast ascent
FREEDIVING
  • Depth alarm
  • Dive time alarm
Recommended products
Support for Suunto Nautic
