Free shipping on all orders over 130 £
Satisfied or your money back
SKU: SS023588000
Suunto Flow Restrictor Transmitter Kit
Sale priceBZ$48
The Suunto Flow Restrictor for Suunto Wireless Tank Pressure Transmitter
Quantity
BZ$48
Add to cart
The Suunto Flow Restrictor is used with the Suunto Wireless Tank Pressure Transmitter. You should remove the restrictor only for cleaning or changing scuba gear. The restrictor must be re-installed before using the transmitter again.
The Suunto Flow Restrictor Transmitter Kit contains one Type A and one Type B flow restrictor. The shorter Flow Restrictor Type A is used when the Suunto transmitter is installed directly to a first-stage regulator high pressure port.
The longer Flow Restrictor Type B is used when the Suunto transmitter is connected to a high pressure hose extension, with the hose attached to the first stage regulator high pressure port.
The Suunto Flow Restrictor Transmitter Kit also contains a Suunto Wireless Tank Pressure Transmitter Quick Guide with installation instructions.
