1 / 16
Refurbished Suunto Core Alpha Stealth Sports Watch
1/16
Money-back guarantee
30-Days Return
Global Support
SKU: SS050504000
Suunto Core Alpha
Stealth
Sale priceBZ$481
Rugged Outdoor Watch Designed for Off-Grid Adventures
  • Mineral crystal display with durable aluminum bezel
  • Night vision Goggle compatible red backlight for stealth use
  • ABC sensors: altimeter, barometer, compass, plus weather tracking
  • Water resistant up to 30 meters; suitable for shallow snorkeling (10 m)
  • Time, date, and multiple watch functions for everyday utility
  • Up to 12 months of battery life in time mode
Choose Your Color
Quantity
30-Days Return
Global Support
BZ$481
Add to cart
SUUNTO CORE ALPHA
Suunto Core Alpha packs the key outdoor features in robust construction with a comfortable yet durable textile strap. Combining an altimeter, barometer and compass with weather information, it will bring out the explorer in you. The night vision goggle friendly red backlight helps you stay unnoticed when hunting.
Suunto Core Alpha is designed and made in Finland with the quality that Suunto is known for. Tested to military standards (MIL-STD-810), the watch will make sure your journey is safe and successful even in the toughest and most demanding conditions. Suunto Core Alpha has passed 9 tests, including pressure, heat/cold, shock, drop, freeze/thaw, rain, humidity and dust.
Key features
Barometer
Compass
Altimeter
Red backlight
Weather functions
Sunrise and sunset times
30 m water resistant
Benefits
  • Altimeter
  • Barometer
  • Compass, adjustable declination
  • Temperature
  • Storm alarm
  • Sunset/sunrise times
  • Tested to military standards
  • Made in Finland
  • Red backlight, night vision goggle friendly
  • Textile strap (Berry amendment compliant)
  • User replaceable battery (CR2032), battery life ~12 months
  • Multiple watch, date and time functions
  • 30 m / 100 ft water resistance
  • Depth meter for snorkeling (10 meters)
  • Metric and imperial units
  • Multilingual menu: EN, DE, ES, FR
SPECIFICATIONS
  • Measurements
    49.5 x 49.5 x 15.1 mm / 1.95 x 1.95 x 0.59 "
  • Weight
    67 g / 2.36 oz
  • Bezel material:
    Aluminum
  • Glass material:
    Mineral crystal
  • Case material:
    Composite
  • Strap material:
    Textile
  • What's in the box?
    Suunto Core Alpha Stealth and Quick Guide
  • Country of manufacture
    FI
TECHNICAL SPECIFICATIONS
  • Bezel material
    Aluminum
  • Glass material
    Mineral crystal
  • Case material
    Composite
  • Strap material
    Textile
  • Weight
    67 g / 2.36 oz
  • Wrist sizes
    140-240 mm
  • Water resistance
    30 m
  • Battery type
    CR2032
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Countdown timer
  • Stopwatch timer
  • Language
    EN, DE, ES, FR
  • Backlight
    LED
  • Configurable backlight
    activation: 1 button, all buttons
  • Button lock
  • Display type
    matrix
  • Battery indicator
    low battery indicator
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • In time mode
    12 months
COMPASS
  • Digital compass
  • Direction scale
    degrees
  • Needle
    north indicator
  • Compass accuracy
  • Compass resolution
OUTDOOR FUNCTIONS
ALTIMETER
  • Barometric altitude
  • Altitude graph
  • Altitude difference
  • Total ascent/descent
    air pressure based
  • Automatic alti/baro profile
  • Log recording rate
    1, 5, 10, 30, 60 s
  • Resolution
    1 m
  • Range
    -500 - 9000 m
WEATHER
  • Sunrise/sunset times
  • Storm alarm
  • Sea level pressure
  • Temperature
  • Temperature display range
  • Temperature resolution
  • Pressure resolution
    1 hPa / 0.03 inHg
  • Max weather recording length
    7 days
  • Sea level pressure graph
  • Weather trend indicator
SPORT EXPERTISE
HUNTING
  • Red backlight, compatible with night vision goggles
DIVING FUNCTIONS
FREEDIVING
    10 m
SUPPORT FOR SUUNTO CORE
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
